Forum: Old versions
Topic: skin pioneer wego 1 problems with virual dj 7
Hey i'm using almost an half year the pioneer wego 1 skin and sometimes i'm having troubles with my chanel from deck 2 . When i put the chanelfader completely up (openn sometimes it go a few (alittlebit)seconds down on the skin then i have to push it to the top untill it stops . its not always sometimes . now the question is is this chanel from my pioneer wego broken or is this a skin problem . What can i do now to fix this
geposted Mon 18 Jan 16 @ 3:26 pm
the skin doesn't send midi info that would move the fader so i would assume it is probably the wego with a issue.
one time i move the fader A verry quick to the top and the fader on the skin doesn react .s o i thought. can this problem be fixed because my controller is not jet 2 years .
maybe check for firmware update it could fix the issue :-)
