Yes.
Do you want it to be toggle or a momentary press ? (SHIFT)
geposted Mon 25 Jan 16 @ 7:24 pm
Can we try the toggle first, lol!
I think that'll be fine but I wont be able to try till tonight.
Thanks again, most appreciated!
geposted Mon 25 Jan 16 @ 8:35 pm
Just tried the newest mapping and that is exactly how I wanted it!!
Thank you!!
Thank you!!
geposted Tue 26 Jan 16 @ 12:31 am
Cool! :)
geposted Tue 26 Jan 16 @ 1:59 pm
Hi....would either one of you mind sharing this mapping.. I was looking for this exact thing for either the dicers or launchpad..thanks. Djtrock313@gmail.com
geposted Mon 13 Jun 16 @ 11:51 am
If you use VirtualDj 8.2 you can download the pretty much improved version of this code here:
https://virtualdj.com/plugins/?addonid=80399
If you're not using VirtualDj 8.2 yet you can either wait until it becomes "public" for all users, or you can get it by following the instructions here:
https://virtualdj.com/forums/210031/General_Discussion/_NEW__VirtualDJ_8_2.html
geposted Mon 13 Jun 16 @ 12:04 pm
PS: Neither launchpad or dicers are compatible with the new pads system on VirtualDj 8.2
However, you will be able to see the code through pad editor and copy the actions on your own mapper for the buttons you want:
geposted Mon 13 Jun 16 @ 12:52 pm
yes I'm using the new 8. 2 okay thanks for the info figured I would try LOL didn't really want to get the sp1 but maybe I will.. I'm quite sure of my kontrol Z2 won't be able to do it either then
geposted Mon 13 Jun 16 @ 1:11 pm
Currently only controllers with 8 pads per side are remapped to support the pads system.
geposted Mon 13 Jun 16 @ 1:12 pm
Jus hooked up and realize that the dicers are boteven working dince i yograded to 8.2 ..uh oh smh
geposted Mon 13 Jun 16 @ 1:48 pm
I don't think there's any reason they shouldn't work though...
Have you tried to use "factory default" mapping for them ?
geposted Mon 13 Jun 16 @ 2:32 pm
O ok..but i thought i saw slicer codes on novation mapper page..thanks for the info
geposted Mon 13 Jun 16 @ 3:03 pm
Dicers did start back workin after reseleting factory default ..thank you
geposted Mon 13 Jun 16 @ 3:04 pm
geposted Mon 13 Jun 16 @ 3:06 pm
