Forum: Old versions
Topic: allen heath zed fx
how do i record with vdj on an allen heath zfx mixer.
recording sound ok but not microphones
geposted Thu 28 Jan 16 @ 5:47 pm
Please provide more info...
Which Zed FX is it? There are lots of different models.
How are you interfacing VDJ and the Zed FX? Are you trying to use VDJ's onboard recording option or are you trying to record with/from the Zed FX?
Where are the mics plugged in?
hi zfx 10 trying to record from vdj.mikes are in m1 m2
Hi trying to record thru vdj music ok but mikes on allen heath zed fx 10 in channels m1 m2 will not record]
I asked how you were interfacing the two (VDJ and the Zed)...
In other words, how have you connected them together? Are you using the USB audio interface on the Zed? If so, in what way?
Are you using the Zed as an INPUT to VDJ (in which case the mics plugged into the Zed will record to VDJ), or as an OUTPUT (sending the audio from VDJ into the Zed?
If you're doing the latter, then of course the mics (plugged into the Zed) will not record in VDJ - because VDJ is first in the chain. You'd be recording BEFORE the sound had reached the Zed (where the mics get mixed in).
VDJ (recording) -> Zed (mics) = no mics being recorded to VDJ. Zed (mics) -> VDJ (recording) = mics will record.
got it thank you
