Forum: VirtualDJ Skins
Topic: sampler volume slider
This doesn't work for me:
<slider action="sampler_volume 3" orientation="vertical" direction="up">
It's the volume slider for the third sampler slot. Is this syntax wrong?
geposted Sat 30 Jan 16 @ 5:07 pm
Never mind. I solved it by using sampler_volume_master instead.
geposted Sat 30 Jan 16 @ 5:13 pm
sampler_volume 3 will still work fine, if of course, there is a Sample in slot 3.
geposted Mon 01 Feb 16 @ 1:09 pm
Not trying to hijack but I think this is along the same lines....
Ok so I have routed my sampler out of deck 5, can I still control the volume of different samples??
The more I think about it the answer is probably gonna be yes, lol!!
geposted Mon 01 Feb 16 @ 2:51 pm
Yes, the answer is yes! ;)
geposted Mon 01 Feb 16 @ 4:07 pm
