I got the DDJ SX2 that doesnt have any jump buttons like forward or backwards..the only thing to "small jumps" in the songs is too turn the "fx mode" button either way.
I want this button to jump 4 beats forward and backwards (in sync), I have tried to change the original script but it doesnt work ?
The original one:
var_equal '$fx1' 1 ? param_greater 0 ? deck 1 goto +1 : deck 1 goto -1 : var_equal '$fx1' 2 ? param_greater 0 ? deck 2 goto +1 : deck 2 goto -1 : var_equal '$fx1' 3 ? param_greater 0 ? deck 3 goto +1 : deck 3 goto -1 : var_equal '$fx1' 4 ? param_greater 0 ? deck 4 goto +1 : deck 4 goto -1 : param_greater 0 ? deck left goto +1 : deck left goto -1
The original one:
geposted Thu 11 Feb 16 @ 3:38 pm
Just replace -1/+1 with -4/+4
geposted Thu 11 Feb 16 @ 4:19 pm
Thats what I tried :-(
geposted Thu 11 Feb 16 @ 4:31 pm
"FX1_ENC_BEATS" for "goto +1/-1" and "SHIFT_FX1_ENC_BEATS" for goto +4/-4" by default
geposted Thu 11 Feb 16 @ 5:06 pm
Most likely you erased a space by mistake and that made the entire action do not function properly.
Try to copy/paste this:
var_equal '$fx1' 1 ? param_greater 0 ? deck 1 goto +4 : deck 1 goto -4 : var_equal '$fx1' 2 ? param_greater 0 ? deck 2 goto +4 : deck 2 goto -4 : var_equal '$fx1' 3 ? param_greater 0 ? deck 3 goto +4 : deck 3 goto -4 : var_equal '$fx1' 4 ? param_greater 0 ? deck 4 goto +4 : deck 4 goto -4 : param_greater 0 ? deck left goto +4 : deck left goto -4
Mind you that this code works only on LEFT side of the controller. For the right side you need to change the FX2_ENC_BEATS with this code:
var_equal '$fx2' 1 ? param_greater 0 ? deck 1 goto +4 : deck 1 goto -4 : var_equal '$fx2' 2 ? param_greater 0 ? deck 2 goto +4 : deck 2 goto -4 : var_equal '$fx2' 3 ? param_greater 0 ? deck 3 goto +4 : deck 3 goto -4 : var_equal '$fx2' 4 ? param_greater 0 ? deck 4 goto +4 : deck 4 goto -4 : param_greater 0 ? deck right goto +4 : deck right goto -4
geposted Fri 12 Feb 16 @ 8:50 am
Thanks Ph
Will try when I get the time :-)
geposted Fri 12 Feb 16 @ 6:17 pm
Worked Perfect...
Thank you again
Thank you again
geposted Sat 13 Feb 16 @ 4:28 pm
I must bring this topic to attention again, the new version 8.2 is blocked to copy/paste this script on this button.
Im using the Pioneer DDJ-SX2.
Is this because its not a final release ?
Please, I would like to have some kind of answer from a team member asap.
/ Fredrik
/ Fredrik
geposted Sat 18 Jun 16 @ 4:28 pm
Blocked ?
No, nothing is blocked... You can edit any button/encider/slider as always.
However: Version 8.2 brings some changes to default mapper and definition of some devices in order to support some new functions.
Therefore you may have to redo your own modifications to the new factory default mapper once 8.2 goes out to public release.
geposted Tue 21 Jun 16 @ 9:30 pm
Have tried to modify the factory mapping with version 8.2 b3272.
And this copy/paste is not working.
geposted Wed 22 Jun 16 @ 2:57 pm
Copy/paste working fine here, could you be more specific?
geposted Wed 22 Jun 16 @ 4:22 pm
When Im in the settings for the controler ddjsx2 I cant copy the script from phantom and paste it into the window.
This worked fine before, now I can not copy anything and put it into that window.
geposted Thu 23 Jun 16 @ 6:16 pm
It's working OK here, I can use the right click context menu or Ctrl+C/Ctrl+X/Ctrl+V.
geposted Thu 23 Jun 16 @ 9:13 pm
Right click wont work.
But using ctrl/v works..thank you !
geposted Fri 24 Jun 16 @ 5:35 am
