I use VDJ8 for music video projection whilst Dj-ing. Tonight for no apparent reason it wouldn't project to second screen, instead it made the video screen appear larger on my laptop. I have been using VDJ 7 for years without problems but since using VDJ 8 this has happened twice and I can't work out why. Any suggestions?
geposted Sat 13 Feb 16 @ 10:43 am
If your secondary screen (projector) is correctly set to "Extended mode" (and not clone), then you can select the Display that you want the Video to maximize, by right-clicking on the Master Output Preview window in the VIDEO panel (of the default skin)
geposted Sun 14 Feb 16 @ 11:37 am
Thanks Djdad, that's solved my problem.
geposted Tue 16 Feb 16 @ 8:41 pm
