I was looking through possible commands. I had two issues. The first is for Countdown, I am trying to make a script to disable certain effects like TellyMedia from covering up a triggered Video sample when it is time to show a special clip. So "effect_active 'TellyMedia' " will toggle the effect On or Off. I want to make a script that will turn it off only if it is running, but not turn it on if it is not currently active.
My other issue is, when I use "effect_active 'TellyMedia' " it toggles the effect on or off one deck one only. I would like to toggle it on or off on the Master output, like pressing the skin button deos. I am sure I am just missing something here, but I am not seeing it at the moment. This was just an issue when I activate the effect with the button on the skin. Then I go to turn it off with my scripted key sequence, but instead of turning it off, it also turns on for deck 1. Which is odd behavior
geposted Thu 18 Feb 16 @ 1:42 am
deck master effect_active "tellymedia" off
That should cover both your questions I think
geposted Thu 18 Feb 16 @ 5:12 am
I think so, thank you!
geposted Thu 18 Feb 16 @ 4:59 pm
