Discussion about Numark NV Custom Mapping
geposted Fri 19 Feb 16 @ 5:05 pm
I receive an error on the line 594758160 of your xml file. Thanks to work on that controler.
geposted Mon 22 Feb 16 @ 2:07 am
There is only 146 lines in the xml file ?
which of the 3 files is it ?
the controller or one of the 2 displays ?
geposted Tue 23 Feb 16 @ 1:29 am
Updated mapping for some errors.
Added overview.
Added skin for 12inchskinz
Added overview.
geposted Tue 23 Feb 16 @ 11:07 pm
File name error I think is Two (.) on MS that mess up file name! DJPP.dk.xml Use only one (.)
Is it possible to add BLEEP button. REVERSE work fine but no BLEEP. var 'shift' ? reverse : dump while_pressed
Me I add FX PUSH = prelisten
Do you have solution for FX A and B button for two deck FX ?
Good job !!!
Good job !!!
geposted Sat 12 Mar 16 @ 9:37 pm
Please don't swear on the forums.
Thanks for understanding.
geposted Sat 12 Mar 16 @ 10:54 pm
