Discussion about vinyl dj two
geposted Fri 19 Feb 16 @ 6:03 pm
Any chance of a longer wave bar? Maybe on top or bottom? Long shot, but I figured I'd ask
geposted Fri 19 Feb 16 @ 8:54 pm
Congratulation on your new skin, use it on a party this weekend I had and it was very useful...Ps I would add a Crossfader control right on the bottom of the vertical WAVE and stretch the vertical WAVE until where the short horizon WAVE end also will remove the top short horizontal WAVE and put it in full length between the playing list and top skin control (Right in the MIDDLE) also if possible make it into a 4 Decks and finally make into a 1920x1080 Think about i hope to see an upgrade soon...Thanks!!!
geposted Sun 21 Feb 16 @ 7:26 pm
updating
geposted Sun 21 Feb 16 @ 11:28 pm
geposted Mon 22 Feb 16 @ 3:20 am
Awesome! Looking forward to the update to release!
geposted Mon 22 Feb 16 @ 4:02 pm
GREAT...That's What I Talking About...Now if is possible can you put a Crossfader control right on the bottom of the vertical Scratching WAVE so we can Manually (MIX) Crossfade from one Deck to the other Deck?...PS Glad you took off the Blue & Red Square it was too much for the Eyes...Best Regard And Thanks!!!
geposted Mon 22 Feb 16 @ 7:00 pm
next version 1.3 soon
geposted Thu 25 Feb 16 @ 8:56 am
Nice! I hope it has the overlapping rhythm bars at the bottom also!!! Cant wait till this releases!!!
geposted Thu 25 Feb 16 @ 8:36 pm
Mr. Fandos Dj Much better, Any possibility to make it into a 1920x1080 Resolution?
Ps will that be asking for too Much? ... Thanks for the Nice Upgraded Skin Mr. Fandos Dj & Keep up the good Work!!!
geposted Sun 28 Feb 16 @ 4:04 pm
Can you add a full Browser?
geposted Sun 28 Feb 16 @ 7:13 pm
sorry my bad posted this by mistake!!!
geposted Sun 28 Feb 16 @ 7:14 pm
Any chance of adding the overlapping rhythm bar as a choice for the large wave area?
geposted Wed 02 Mar 16 @ 4:21 pm
working on the next version . 1.4
I add:
crossfader video
volume level
alert track end
change pannel video on scratch
I add:
crossfader video
volume level
alert track end
geposted Thu 03 Mar 16 @ 9:08 am
Looking Good Mr. Fandos DJ Great Idea But Can You Make It Into A 1920x1080 Resolution? It Will Give You More Room To Work With As Well...Best Regard & Keep Up The Good Work.
geposted Thu 03 Mar 16 @ 4:43 pm
geposted Fri 04 Mar 16 @ 7:40 pm
Hell yes! By far the best skin out for VDJ 8!!! What does it look like with the standard overlapping rhythm bars?
geposted Fri 04 Mar 16 @ 7:47 pm
geposted Sat 05 Mar 16 @ 12:13 am
Hi again Mr. Fandos DJ, when is the new upgrade V1.4 or V1.5 coming out? Can't way to give a new spin...Thanks & Best Regard.!!!
geposted Fri 11 Mar 16 @ 1:59 am
The new 1.4 looks really good ,but for some reason my bottom wavecolor its not working only showing the red and blue waves ,what i need to do to active it,im using mac.
geposted Sat 12 Mar 16 @ 2:14 am
