Hello,
Is it possible to use VirtualDJ 8 with Open Sound Control (OSC)? Specifically, I'd like to control Virtual DJ from an external application, using OSC, if possible.
Thank you.
Thank you.
geposted Sun 21 Feb 16 @ 4:38 pm
not sure about this, but did you had a look at the virtualdj remote control yet ?
http://www.virtualdj.com/products/vdjremote.html
geposted Sun 21 Feb 16 @ 5:19 pm
There is no OSC support in VDJ8. You would have to create your own OSC plugin.
geposted Sun 21 Feb 16 @ 5:45 pm
RobRoy, SBDJ many thanks for your responses. I want to control VirtualDJ from my own application.
Indeed, a custom plugin would make sense; it would be a "clean" solution.
I have now found an alternative (indirect) approach, which does not require additional programming, proposed in the following article:
https://jaredsprojects.wordpress.com/open-sound-control/
It relies on using PD, a utility to convert OSC data to MIDI data, which allows for controlling VirtualDJ via MIDI.
http://puredata.info/downloads/pure-data
geposted Sun 21 Feb 16 @ 8:31 pm
