Forum: VirtualDJ Plugins
Topic: New Tool: Summonizer - Page: 1
My new tool just got accepted :)
It is called Summonizer and it is able to create a playlist or virtual folder out of an input file.
An example:
You are surfing the web and find a sampler or a nice mix with a tracklist.
Just copy the tracklist into a new .txt file and save it.
Open the Summonizer, select the created .txt file, choose your output format (virtual folder or playlist), give it a name and hit "Search".
The Summonizer will now search through your VirtualDJ databases and present you a list of "matches" of those tracks that are already in your collection.
After the next click on the "Create" button a virtual folder (or playlist) will be created, including all the found tracks, ready to be played in VDJ.
Just give it a try.
https://virtualdj.com/plugins/?addonid=80364
geposted Mon 22 Feb 16 @ 10:13 am
thank you sounds great
Now that sounds like a very good idea and could be useful. Thank you.
This sounds nice, any chance of a Mac version??
I'm gonna try it out on my PC though.
I'm not able to develop a mac version.
First and foremost because I don't own a mac. And second, even if I had one I don't have the knowledge to write a mac compatible version.
Any way to force this to make a virtual folder or playlist even though I don't have the tracks??
Kinda like a cloudlists, even though I don't have the tracks the titles, artist still show up.
It is possible. I'll make that as an option.
Awesome!
For all of you that already downloaded the tool.
A new version is online which fixes an error while reading the database.
Anyway you could share this code with Scott (SBDJ) and see if he can port this over to the Mac side??
Sure, why not.
Any word on forcing a playlist being made/saved regardless of having the tracks or not??
Thanks.
Yup,... Still on the todo list.
I was being noticed of another critical bug. A fix is in development and will be submitted for review in the next few hours.
After everything runs fine the next step is improvements and requests.
Please keep in mind that I just don't find the time to work 2 or 3 hours a day on the tool.
I'm very busy doing some major projects on my job which causes a lot of extra hours atm. After that there is a family that too want to spend some time with me.
Yup well aware as i myself work 70 hours a week, family (5 kids), my wife is a full time student and gig on the weekends.....
Never enough hours in a day......
Huey, I've found a great way to display missing songs.
I'll just do it the "VDJ way" :D
It will look like that at the end:
The Tracks with the blue Icon are missings track. If you drag them onto a deck, a Netsearch / CU search is performed.
Awesome!! That's perfect!!
And another little addon in testing ;)
that looks interesting
Doesnt start at all for me ?!
Nothing is happening when i try to install / start the program.
Vdj on or of when hitting the program, have searched for it in firewall with no sign of it ?
How is this program suppose to be installed ?
Using PC
Same for me on windows10 (nothing happens) and with windows XP, I have an error message when I try to install it.
61%
