Will this new display-unit be supported by VDJ so we can use it with other controller eg. Vestax VCI400 or Denon 6000 MK2 as a add on?
link:
http://djtechtools.com/2016/01/20/namm-2016-numark-dashboard-heads-up-display-for-serato-djs/
Would be great; we could pimp our controllers ;o)
link:
geposted Tue 23 Feb 16 @ 12:59 am
We can't tell if it will be supported or not.
What we can tell is that VirtualDj team will try to support it as it does with any other controller. If it uses a similar protocol with NS7 III then most likely support will come some at some point after we finish support for NS7 III screens.
geposted Tue 23 Feb 16 @ 12:58 pm
Thanks for your reply. So let's wait and see....
geposted Tue 23 Feb 16 @ 1:54 pm
Is this supported yet ????????
geposted Sun 13 Mar 16 @ 4:04 pm
Best to have a look here if you are interested in what is supported -> https://virtualdj.com/wiki/VirtualDJ8%20Controllers.html
it will save everyone time :-)
geposted Sun 13 Mar 16 @ 4:52 pm
So I've looked at the link that is above and not there. I also see that the Numark NSIII is now supported. Is the Numark Dashboard also supported by VDJ8 ?????
geposted Sun 20 Mar 16 @ 7:00 pm
the NS3 is listed as coming soon if you read carefully :-)
geposted Sun 20 Mar 16 @ 7:02 pm
