I am using a denon mc 4000 with virtual dj 8 pro . can anyone tell me how to set the 3 effects on each deck . It currently seems likew ony efx #1 is working .
geposted Thu 25 Feb 16 @ 1:44 am
Multi FX effects mode.
geposted Thu 25 Feb 16 @ 7:11 pm[ selected best answer by PhantomDeejay on Thu 25 Feb 16 @ 8:24 pm ]
Hold SHIFT down and then press the TAP button to toggle between the Single FX and
Selected as best answer geposted Thu 25 Feb 16 @ 7:11 pm
geposted Fri 26 Feb 16 @ 2:28 pm
To the OP how well do you like this controller?? Been thinking of getting something smaller and this one has caught my eye.
Any details would be appreciated, Thanks!
geposted Fri 26 Feb 16 @ 3:53 pm
I also have the 4000 and I think it's a great controller. Very well made, the audio and mics are crystal clear. Get yourself a nice case, and go to town!
geposted Thu 03 Mar 16 @ 4:48 am
thanks Rob will try it later today ..
geposted Thu 10 Mar 16 @ 10:51 pm
the 4000 controller is a solid piece . I use to own the mc6000 .... then went to a pioneer ddj unit and was having hardware issues. I bought the 4000 recently and am so happy with it . gain control, master booth outs , 2 mics - how can you go wrong . the unit was built for the mobile entertainer is priced right and has roadworthiness. I don't scratch so cant say much about jog wheels
geposted Thu 10 Mar 16 @ 10:58 pm
This does work but doesnt change the view on the screen, I need this to reflect on the screen as well. Ive tried the stock VDJ skin as well as SliverSleek and the change isnt reflected on screen.
I havent/cant memorize every parameter for every fx so its important I see them on screen. Can anybody help me get this to change using Phantoms SliverSleek please???
Other then that I love my 4000.
geposted Sat 12 Mar 16 @ 5:31 am
OK disregraud my last post, I got everything sorted out. My buttons now reflect on screen.
Now this controller is truly badass!!
geposted Sat 12 Mar 16 @ 6:47 am
