There was a screen capture plug in for VDJ7 that I used all the time to capture screen shots and use as splash pages. It was pretty simple to use. I am now using vdj8 and I am trying to find a similar plug in. Can anyone help me out on this one? Thanks
geposted Mon 29 Feb 16 @ 10:08 pm
Try this: http://www.virtualdj.com/plugins/index.html?addonid=80375
If you run into trouble then (as per the notes on the download) please make sure you have installed this:
https://www.microsoft.com/en-us/download/confirmation.aspx%3Fid%3D35
geposted Tue 01 Mar 16 @ 5:19 pm
Make sure you DON'T INSTALL THE BING BAR! when installing the direct x! (unless you like that kinda thing!)
geposted Tue 01 Mar 16 @ 5:25 pm
