Hello I tried connecting a VCi-100 with firmware 1.4 everything works OK, except for the pitchfaders and the 4th FX button, on each FX bank (master,A,B)
can this have a fix please
thank you
thank you
geposted Wed 02 Mar 16 @ 10:54 pm
how can I change the pitch midi codes? my VCI-100 has the DJTechTools firmware 1.4, so it has 14-bit midi on the pitch faders.
I used Bome Midi Translator and found that pitch faders on VCI-100 1.4 firmware, have these codes/notes
left pitch : min 0%= "E1 20 04" at zero 50%= "91 0C 7F" and max 100%= "E1 40 7B"
right pitch: min E2 20 04 zero=91 0D 7F max=E2 40 7B
how can I add these codes to the mapper on vdj8?
thank you
thank you
geposted Fri 20 Jan 17 @ 9:17 pm
I am afraid you will have to create a custom definition. The native definition appears to have Midi CC (Bx) for the pitch sliders, while the firmware 1.4 appears to offer Midi Pitch (Ex). Such a difference in sent data, cannot be handled in the mapping.
<slider pitch="true" name="PITCH" deck="1" channel="1" inverted="true" />
<slider pitch="true" name="PITCH" deck="2" channel="2" inverted="true" />
Can't you flash a different (older firmware) ?
geposted Fri 20 Jan 17 @ 9:24 pm
thank you, where do input that code?? in the vci-100 custom mapping xml?
edit: so I created another vci-100.xml in the devices folder and added the code lines , no success
how do I flash another firmware??I would like to flash the original one
geposted Fri 20 Jan 17 @ 9:36 pm
