hi i have a mixtrack 2. the effects parameters dont seem to work ie. when pressing shift key i can change effect on all 3 and i can use the fx1 vierable 1 to manipulate effect but not 2 and 3. i have downloaded the skin for the mixtrack 2 the instructions say fx2 and fx3 should work but i cant get them to work can u help me please thanks in advace
geposted Sat 05 Mar 16 @ 4:03 pm
The knobs should properly control the 1st parameter of the selected effects on each of the 3 slots.
Most likely you are trying to use a version 7 skin and the functions may not match.
I suppose you see the knobs moving on the skin properly if the default ver 8 skin is used (or some other), correct ?
geposted Mon 07 Mar 16 @ 1:51 pm
