I need like MAJOR help on this. So i just got an early 2011 macbook pro. And I've been trying to instal VDJ Home for the past couple of weeks now. and I just can't seem to get it. I've gotten a new bigger hard drive and installed a fresh copy of El capitan. Turns out VDJ 7 isn't supported on El Capitan but it seemed weird since I have another MB Late 2008 that works fine with it. I talked to a representative of VDJ and they said that El Capitan isn't supported and that Yosemite is the last supported OS. Ok, so I clean wiped the hard drive AGAIN and I installed Yosemite. And that doesn't seem to work either. This is what I get in the Virtual Dj Home Quit Unexpectedly text box.(look at error message below) I don't know what any of that means. I' not sure if it's because I have 8 gb of ram on this Macbook pro instead of the 4 GB on the other one. The OS didn't install correctly. I honestly don't know. I just need help please.
Process: VirtualDJ Home [611]
Path: /Applications/VirtualDJ Home.app/Contents/MacOS/VirtualDJ Home
Identifier: com.atomixproductions.virtualdjhome
Version: 7.4.7 (7.4.7)
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: VirtualDJ Home [611]
User ID: 501
Date/Time: 2016-03-10 20:58:50.220 -0800
OS Version: Mac OS X 10.10.5 (14F1605)
Report Version: 11
Anonymous UUID: CCC92308-92BB-F86E-CB7B-41F86132DC4C
Time Awake Since Boot: 1400 seconds
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000bf7ffffc
VM Regions Near 0xbf7ffffc:
Submap 0000000090000000-00000000b0000000 [512.0M] r--/rwx SM=SHM machine-wide VM submap
--> Stack 00000000bc000000-00000000bf800000 [ 56.0M] ---/rwx SM=NUL
Stack 00000000bf800000-00000000c0000000 [ 8192K] rw-/rwx SM=COW
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_pthread.dylib 0x047c4749 __mtx_droplock + 378
1 libsystem_pthread.dylib 0x047c44d4 pthread_mutex_unlock + 67
2 libobjc.A.dylib 0x0257b46f look_up_class + 99
3 libobjc.A.dylib 0x02588088 connect_class(objc_class*) + 69
4 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
5 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
6 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
7 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
8 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
9 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
10 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
11 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
12 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
13 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
14 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
15 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
16 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
17 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
18 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
19 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
20 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
21 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
22 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
23 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
24 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
25 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
26 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
27 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
28 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
29 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
30 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
31 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
32 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
33 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
34 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
35 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
36 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
37 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
38 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
39 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
40 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
41 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
42 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
43 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
44 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
45 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
46 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
47 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
48 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
49 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
50 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
51 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
52 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
53 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
54 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
55 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
56 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
57 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
58 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
59 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
60 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
61 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
62 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
63 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
64 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
65 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
66 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
67 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
68 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
69 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
70 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
71 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
72 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
73 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
74 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
75 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
76 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
77 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
78 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
79 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
80 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
81 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
82 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
83 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
84 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
85 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
86 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
87 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
88 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
89 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
90 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
91 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
92 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
93 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
94 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
95 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
96 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
97 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
98 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
99 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
100 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
101 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
102 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
103 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
104 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
105 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
106 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
107 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
108 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
109 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
110 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
111 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
112 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
113 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
114 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
115 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
116 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
117 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
118 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
119 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
120 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
121 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
122 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
123 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
124 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
125 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
126 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
127 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
128 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
129 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
130 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
131 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
132 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
133 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
134 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
135 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
136 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
137 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
138 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
139 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
140 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
141 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
142 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
143 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
144 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
145 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
146 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
147 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
148 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
149 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
150 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
151 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
152 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
153 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
154 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
155 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
156 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
157 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
158 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
159 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
160 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
161 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
162 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
163 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
164 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
165 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
166 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
167 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
168 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
169 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
170 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
171 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
172 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
173 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
174 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
175 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
176 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
177 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
178 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
179 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
180 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
181 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
182 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
183 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
184 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
185 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
186 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
187 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
188 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
189 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
190 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
191 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
192 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
193 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
194 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
195 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
196 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
197 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
198 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
199 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
200 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
201 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
202 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
203 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
204 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
205 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
206 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
207 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
208 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
209 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
(took out lines 210-450 for room at the bottom{If they're important please notify me})
451 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
452 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
453 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
454 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
455 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
456 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
457 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
458 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
459 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
460 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
461 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
462 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
463 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
464 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
465 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
466 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
467 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
468 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
469 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
470 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
471 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
472 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
473 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
474 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
475 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
476 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
477 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
478 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
479 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
480 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
481 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
482 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
483 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
484 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
485 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
486 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
487 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
488 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
489 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
490 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
491 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
492 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
493 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
494 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
495 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
496 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
497 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
498 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
499 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
500 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
501 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
502 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
503 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
504 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
505 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
506 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
507 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
508 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
509 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
510 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
511 libobjc.A.dylib 0x02588096 connect_class(objc_class*) + 83
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0x0000cef3 ecx: 0x00000000 edx: 0x02765a18
edi: 0x02765a20 esi: 0x0000cef3 ebp: 0xbf800058 esp: 0xbf800000
ss: 0x00000023 efl: 0x00010206 eip: 0x047c4749 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0xbf7ffffc
Logical CPU: 0
Error Code: 0x00000006
Trap Number: 14
Binary Images:
0x1000 - 0xa16fef +com.atomixproductions.virtualdjhome (7.4.7 - 7.4.7) <5A6F01B5-5A7C-E294-9CFE-F7158D3F30E4> /Applications/VirtualDJ Home.app/Contents/MacOS/VirtualDJ Home
0x156f000 - 0x161cfff libcrypto.0.9.7.dylib (106) <19669D99-DC79-3715-BC3A-850016DDDD7F> /usr/lib/libcrypto.0.9.7.dylib
0x1660000 - 0x166dff7 libbz2.1.0.dylib (36) <6BC7B049-8F03-3217-9840-B1804CCBF742> /usr/lib/libbz2.1.0.dylib
0x1673000 - 0x1764ffb libiconv.2.dylib (42) <4AF77F10-0BEC-3BE0-99DF-C5170EDB316B> /usr/lib/libiconv.2.dylib
0x1772000 - 0x1772fff com.apple.Carbon (154 - 157) <CA90E930-DE59-3AD9-B158-3A940BA1FA8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x1775000 - 0x177cfff com.apple.agl (3.3.0 - AGL-3.3.0) <D6B07000-4170-3007-AFD0-C51E69224B37> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x1783000 - 0x190bff7 com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <CA1E6D99-F534-3D3B-9AA5-038E171AD0A9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x199a000 - 0x199afff com.apple.audio.units.AudioUnit (1.12 - 1.12) <CFB6243A-1613-3468-88CE-1DDBEC1E6984> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x19a0000 - 0x19a0fff com.apple.Cocoa (6.8 - 21) <6AF80DDB-C28E-36FF-BC11-D7D561AC52A9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x19a3000 - 0x19f8ff3 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <C09B57A4-83B8-389C-8B3F-1ECBBB5052C1> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x1a1a000 - 0x1a53ff7 com.apple.audio.midi.CoreMIDI (1.10 - 88) <20E11181-3421-3D46-97C0-347F68ED816A> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x1a76000 - 0x1af3ff3 com.apple.framework.IOKit (2.0.2 - 1050.20.2) <84299E45-C5F3-365F-AC1B-0EAFF8057112> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x1b27000 - 0x1b35ff3 com.apple.opengl (11.1.6 - 11.1.6) <4F03A0A3-8437-323A-8E12-A389D73C4505> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x1b3d000 - 0x1d02fff com.apple.QuartzCore (1.10 - 361.19) <1E3BC4E7-7008-3802-A563-FBAB6726E332> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x1dbe000 - 0x2044fff com.apple.QuickTime (7.7.3 - 2890.9) <C1F4D7DF-2519-3072-BB97-D69A041E2F1C> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x20ed000 - 0x2377ff3 com.apple.security (7.0 - 57031.40.8) <986D75F2-F340-3DCA-9801-9F2F4DD33E00> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x24a4000 - 0x24a4fff com.apple.Accelerate (1.10 - Accelerate 1.10) <C2367B5B-AE20-3084-A864-104743BE478E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x24a7000 - 0x24b5ff7 libz.1.dylib (55) <DF3B8F77-8931-3A6B-8BDF-DB67315050E6> /usr/lib/libz.1.dylib
0x24bb000 - 0x250efff libstdc++.6.dylib (104.1) <D0EB2C99-5939-3ABA-9C18-D9AD75CE23A1> /usr/lib/libstdc++.6.dylib
0x256e000 - 0x256ffff libSystem.B.dylib (1213) <E0E8DD79-1F63-3335-A0FC-83CC2B03EBE2> /usr/lib/libSystem.B.dylib
0x2575000 - 0x27642ef libobjc.A.dylib (647) <7648C174-3098-3B26-AD20-490DBFFD5D4C> /usr/lib/libobjc.A.dylib
0x2788000 - 0x2788fff com.apple.CoreServices (62 - 62) <08A581EC-2E8B-30CF-B555-64171C8FE5EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x2791000 - 0x2b45ff7 com.apple.CoreFoundation (6.9 - 1153.18) <267B1002-C755-37B4-95CD-92358CF994B8> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x2c95000 - 0x2c95fff com.apple.ApplicationServices (48 - 48) <76C301A4-705B-33DE-BA11-C89DCF1EDCDD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x2c9d000 - 0x2ffeff3 com.apple.Foundation (6.9 - 1154) <4F2854C1-310E-34FC-9ADA-1B16AD93D505> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x31aa000 - 0x31d9fff com.apple.CoreVideo (1.8 - 145.1) <A59466FC-6B5A-3B36-BDD4-AC9CD581B7A1> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x31f5000 - 0x3e21fff com.apple.AppKit (6.9 - 1348.17) <1D891DC4-4E22-30FD-A8AC-1221531BEEA3> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x440e000 - 0x4412ffb libcache.dylib (69) <55501A00-AF64-3554-8F46-8D5AFEDEC332> /usr/lib/system/libcache.dylib
0x4417000 - 0x4423ff3 libcommonCrypto.dylib (60061.30.1) <18B9D797-34BA-3F73-8744-7812DC9AE89C> /usr/lib/system/libcommonCrypto.dylib
0x4430000 - 0x4435ff7 libcompiler_rt.dylib (35) <6630682F-AB76-3E55-BE51-0A3E61B6CFC2> /usr/lib/system/libcompiler_rt.dylib
0x4440000 - 0x4449fff libcopyfile.dylib (118.1.2) <FAF3268F-C580-33D3-A5B4-74B8A8713216> /usr/lib/system/libcopyfile.dylib
0x4450000 - 0x44bcff7 libcorecrypto.dylib (233.30.1) <B62C4F7C-90B1-3ECA-B5EE-3C8A3B8CBA7B> /usr/lib/system/libcorecrypto.dylib
0x44d2000 - 0x44f9fff libdispatch.dylib (442.50.1) <A4EA1B52-2597-36E9-BDE0-89B3D8B0C3E0> /usr/lib/system/libdispatch.dylib
0x4514000 - 0x4517fff libdyld.dylib (353.2.3) <9E52D315-C3CD-30B6-AA06-50B529D9AC38> /usr/lib/system/libdyld.dylib
0x451d000 - 0x451dfff libkeymgr.dylib (28) <06DDCEF8-EB84-3F68-9E19-FD1A12B764FD> /usr/lib/system/libkeymgr.dylib
0x4521000 - 0x4521fff liblaunch.dylib (559.40.1) <65101C3E-CC60-3528-A306-991309171B8A> /usr/lib/system/liblaunch.dylib
0x4528000 - 0x452dff7 libmacho.dylib (862) <48DE74F8-09E3-344F-A82F-665083A3BF8F> /usr/lib/system/libmacho.dylib
0x4532000 - 0x4534ff7 libquarantine.dylib (76.20.1) <8694AC5A-7359-3CC6-8E93-CABFCC919D4B> /usr/lib/system/libquarantine.dylib
0x4539000 - 0x453afff libremovefile.dylib (35) <49DCAF7B-4466-3775-9E58-EA5D7CBA8AE0> /usr/lib/system/libremovefile.dylib
0x4540000 - 0x4557fff libsystem_asl.dylib (267) <85BD88AD-618E-3325-AC31-10DBAB8E9AF3> /usr/lib/system/libsystem_asl.dylib
0x4563000 - 0x4564fff libsystem_blocks.dylib (65) <5D98F022-E863-31D4-8ADE-D53B2AE0D331> /usr/lib/system/libsystem_blocks.dylib
0x4568000 - 0x45fdfff libsystem_c.dylib (1044.40.2) <4C6B5977-D7C9-3EDC-8D14-C00333C72090> /usr/lib/system/libsystem_c.dylib
0x4625000 - 0x4627fff libsystem_configuration.dylib (699.40.2) <B5143118-AB15-3BB9-844D-20471938B639> /usr/lib/system/libsystem_configuration.dylib
0x462d000 - 0x462ffff libsystem_coreservices.dylib (9) <20E66A47-8D67-344A-A393-73926F0E5FB2> /usr/lib/system/libsystem_coreservices.dylib
0x4634000 - 0x4645ff7 libsystem_coretls.dylib (35.40.1) <22F1F179-F6ED-3576-8169-ED44BB59780A> /usr/lib/system/libsystem_coretls.dylib
0x4654000 - 0x465cfff libsystem_dnssd.dylib (576.50.2) <EE1665C5-2827-3BF7-961A-12EAE26DAFA7> /usr/lib/system/libsystem_dnssd.dylib
0x4662000 - 0x468bfff libsystem_info.dylib (459.40.1) <4827C088-2BF0-397F-B9FA-0F91BDF64637> /usr/lib/system/libsystem_info.dylib
0x469f000 - 0x46befff libsystem_kernel.dylib (2782.50.1) <20156462-5B58-3B51-8D05-A2F7195679D5> /usr/lib/system/libsystem_kernel.dylib
0x46d3000 - 0x4706fe3 libsystem_m.dylib (3086.1) <951F633F-57B7-398B-912F-F6ED4DB1C597> /usr/lib/system/libsystem_m.dylib
0x4711000 - 0x472aff7 libsystem_malloc.dylib (53.30.1) <1438C1B7-5CD0-3A01-ACF8-BFC4012541B9> /usr/lib/system/libsystem_malloc.dylib
0x4733000 - 0x4770fff libsystem_network.dylib (412.20.3) <1D1D6444-EB6B-3249-902B-1710C3C0DCCB> /usr/lib/system/libsystem_network.dylib
0x4794000 - 0x479aff7 libsystem_networkextension.dylib (167.40.3) <7856EE13-BFDC-3344-AB7C-91866DC6E3EE> /usr/lib/system/libsystem_networkextension.dylib
0x47a3000 - 0x47acff7 libsystem_notify.dylib (133.1.1) <B8503E99-214B-3AC3-A7CA-CC837ABD7B25> /usr/lib/system/libsystem_notify.dylib
0x47b4000 - 0x47baff3 libsystem_platform.dylib (63) <509993B7-3F26-3360-B899-0BBB15152516> /usr/lib/system/libsystem_platform.dylib
0x47c3000 - 0x47cbfff libsystem_pthread.dylib (105.40.1) <21849EF5-A3B6-34D4-A045-4A68A6C390A1> /usr/lib/system/libsystem_pthread.dylib
0x47d5000 - 0x47d7fff libsystem_sandbox.dylib (358.20.5) <8F74D383-C8B0-32DD-89C1-1E99034AF763> /usr/lib/system/libsystem_sandbox.dylib
0x47dd000 - 0x47dfffb libsystem_secinit.dylib (18) <3CBA3BD3-8BA2-358D-BD1A-A1C3DF5D84E6> /usr/lib/system/libsystem_secinit.dylib
0x47e5000 - 0x47ebff7 libsystem_trace.dylib (72.20.1) <5F23BE77-1C60-3859-B528-C6B3C184C95C> /usr/lib/system/libsystem_trace.dylib
0x47f5000 - 0x47f5fff libunc.dylib (29) <CE960997-9D4A-3848-BAC7-B2255E6765FD> /usr/lib/system/libunc.dylib
0x47f9000 - 0x4800ff3 libunwind.dylib (35.3) <29D9343F-9A0A-3535-B0AE-E7CC761D95EE> /usr/lib/system/libunwind.dylib
0x4807000 - 0x482dff3 libxpc.dylib (559.40.1) <D765980C-9448-3637-AE66-360C7DC2DCEB> /usr/lib/system/libxpc.dylib
0x4845000 - 0x484fffb com.apple.audio.SoundManager (4.2 - 4.2) <4312D0A7-4B6F-3A1E-9A47-24C6E8C65E51> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x4857000 - 0x485bfff com.apple.CommonPanels (1.2.6 - 96) <955375E6-2416-38E1-AFC6-477827119329> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x4863000 - 0x4866ff7 com.apple.help (1.3.3 - 46) <FDF183E4-3B95-3CBD-A390-2536C8E7E258> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x486c000 - 0x4c45ff3 com.apple.HIToolbox (2.1.1 - 758.7) <6BC046E4-02B6-3E08-8565-77E39E4654B9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x4dc9000 - 0x4e1eff7 com.apple.htmlrendering (77 - 1.1.4) <B85A63B9-C9DD-3ECC-B5DC-E12533C7FDF9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x4e45000 - 0x4e59fff com.apple.ImageCapture (9.0 - 9.0) <4B84B5D5-A5F3-3B35-93CE-568A73486B92> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x4e71000 - 0x4f0efff com.apple.ink.framework (10.9 - 213) <F47949BC-ABEE-329B-B568-71C6FEF761F6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x4f38000 - 0x4f77fff com.apple.NavigationServices (3.8 - 215.1) <46D8B66D-CB59-36F5-BD26-FD8309337BB3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x4f9e000 - 0x4fb9ffb com.apple.openscripting (1.6.4 - 162.2) <EC0738BF-B7D0-3C9F-9FC7-97C2D84BE644> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x4fcb000 - 0x4fcdfff com.apple.securityhi (9.0 - 55006) <A0A1E528-E3FA-34D2-AD3B-5C4DF2FE438E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x4fd2000 - 0x4fd9fff com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <5D268178-3812-3777-92A6-D7D3395405B8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x4fe2000 - 0x5038fff libc++.1.dylib (120) <D8DE4962-66CD-3491-904E-9291EEE5E570> /usr/lib/libc++.1.dylib
0x508e000 - 0x529efff com.apple.CFNetwork (720.5.7 - 720.5.7) <8CE218EB-78CD-3757-B185-8FA6CB56F5B5> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x53cc000 - 0x53d4fff com.apple.CoreServices.FSEvents (1210.20.1 - 1210.20.1) <FDCAA783-356F-3CA4-B960-16555CD7E34A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x53db000 - 0x56d9ffb com.apple.CoreServices.CarbonCore (1108.6 - 1108.6) <ABEA5906-26AE-308F-B078-5944ABDF94DF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x574f000 - 0x57f5fff com.apple.Metadata (10.7.0 - 917.36) <6B6C3094-6820-3621-BC4D-3BECECEC5918> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x5847000 - 0x58cefff com.apple.CoreServices.OSServices (640.4 - 640.4) <9C580495-B7C7-3E45-A5A5-0282C8C2B18F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x591f000 - 0x5995ff7 com.apple.SearchKit (1.4.0 - 1.4.0) <3693A221-B615-37D4-9FB1-F5F6CC7EE1A7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x59cf000 - 0x5a33ff7 com.apple.AE (681.5 - 681.7) <1190538F-460A-3168-B1F6-3FE08D98F677> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x5a5e000 - 0x5b5fff7 com.apple.LaunchServices (644.56 - 644.56) <CFF2C4B8-8111-3B9B-A6F7-E2AB33163238> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x5bd6000 - 0x5c05fff com.apple.DictionaryServices (1.2 - 229.1) <627E1C9E-BEDA-32B1-97E1-45BE074FC2C3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x5c25000 - 0x5c65fff libauto.dylib (186) <1609D0F9-6E3A-3C67-87EF-BB0BD93EDAC9> /usr/lib/libauto.dylib
0x5c79000 - 0x5c8afff libbsm.0.dylib (34) <C9F0C608-2794-3F6B-8078-583FC0046039> /usr/lib/libbsm.0.dylib
0x5c92000 - 0x5d11fff com.apple.SystemConfiguration (1.14.4 - 1.14) <796BBD68-8E23-32BF-93DD-9C0EA21DB81B> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x5d48000 - 0x5ed9ff3 libsqlite3.dylib (168.2) <85773EDA-5470-326B-8C21-20A80C89C96A> /usr/lib/libsqlite3.dylib
0x5ef5000 - 0x5febff7 libxml2.2.dylib (26.2) <434EF68C-0413-3BE5-AF71-395A4044D4AA> /usr/lib/libxml2.2.dylib
0x601a000 - 0x6210fff libicucore.A.dylib (531.50) <018CE684-76AA-371A-93C4-50F2EC9CE295> /usr/lib/libicucore.A.dylib
0x62b9000 - 0x62bafff libDiagnosticMessagesClient.dylib (100) <3EE83437-AA9C-356B-810B-589346B73797> /usr/lib/libDiagnosticMessagesClient.dylib
0x62bf000 - 0x62e5ff3 libc++abi.dylib (125) <E9AF8CA1-D54D-37E3-8363-A3E8C0840F71> /usr/lib/libc++abi.dylib
0x62f1000 - 0x62fdff7 libkxld.dylib (2782.50.1) <D61CD648-2007-318A-89C4-53CDADD32D79> /usr/lib/system/libkxld.dylib
0x6302000 - 0x6311ffb libxar.1.dylib (255) <4FF7DB6F-3232-302F-94BC-F1188F78AF25> /usr/lib/libxar.1.dylib
0x6319000 - 0x631cfff libpam.2.dylib (20) <E2F34522-448A-3392-BC1D-6625BEB612B9> /usr/lib/libpam.2.dylib
0x6321000 - 0x6321fff libOpenScriptingUtil.dylib (162.2) <7670C29D-B3A3-3E59-A117-DD7766C07862> /usr/lib/libOpenScriptingUtil.dylib
0x6325000 - 0x632efff com.apple.DiskArbitration (2.6 - 2.6) <D906604A-1D8C-31BF-8F22-EA219FFC858F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x6338000 - 0x6340fff com.apple.NetFS (6.0 - 4.0) <B49F5FC7-8B8D-393A-ABA1-F3214BBC7641> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x6347000 - 0x6352ff7 com.apple.NetAuth (5.2 - 5.2) <3E650FB0-5EB5-3807-8B71-8FAF64D6A0FC> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x635c000 - 0x635efff com.apple.loginsupport (1.0 - 1) <BA8EEAD0-8E97-3219-949B-50AE67F8869E> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x6363000 - 0x63cfff3 com.apple.datadetectorscore (6.0 - 396.1.2) <ED943454-9E6A-32D6-80FC-1C396A5EF4CC> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x6400000 - 0x6404ff3 com.apple.TCC (1.0 - 1) <EE0D6865-A6E0-3BF0-93F1-837C09AA7978> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x640b000 - 0x6765ff7 libmecabra.dylib (666.7) <55A50B97-92D3-3DDC-8E3A-58BC5FFE5E3F> /usr/lib/libmecabra.dylib
0x67ac000 - 0x6baaff7 com.apple.CoreGraphics (1.600.0 - 788.3.2) <FD614BE7-56F4-35AE-9798-31A608EF8133> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x6c46000 - 0x6d5dfff com.apple.CoreText (454.11 - 454.11) <81873C09-46D8-30F8-8D32-28AA923B7C90> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x6de5000 - 0x6f29ff7 com.apple.ImageIO.framework (3.3.0 - 1241) <D75A755E-19BA-3730-9E4C-14D8523B1BFB> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x6f89000 - 0x7000fff com.apple.ApplicationServices.ATS (360 - 375.4) <7039705C-D10D-330E-B09D-69F88DC2FB9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7029000 - 0x70c3fff com.apple.ColorSync (4.9.0 - 4.9.0) <E3442A3A-181A-3C39-86D5-89292AF8115F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7102000 - 0x7156ff7 com.apple.HIServices (1.22 - 523) <F3E2B552-59E8-3E93-AC38-BBCD0021D736> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7189000 - 0x7199ff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <DBECFAD5-DB53-390C-AE92-09549733C861> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x71a5000 - 0x7245fff com.apple.QD (301 - 301) <4DFE3689-59DE-3FBC-806B-6A4056573E52> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7272000 - 0x727fff7 com.apple.speech.synthesis.framework (5.3.11 - 5.3.11) <E7F84974-F272-385D-8A48-DDBD10566CE1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7291000 - 0x7295ffb com.apple.IOSurface (97.4 - 97.4) <FD6AD351-BD60-337C-8D3D-42CDA7EE137C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x729d000 - 0x72bffff com.apple.MultitouchSupport.framework (264.6 - 264.6) <83627B4D-8948-35A7-A76B-7F10AC70B468> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x72cf000 - 0x770afeb com.apple.vImage (8.0 - 8.0) <56F6B317-9D70-3DC5-9868-BB6D7CB6E55D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7755000 - 0x7755fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <F968D12F-F59D-3148-951D-76735C3C1B57> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7758000 - 0x7865fe3 libvDSP.dylib (516) <53F7A960-01E1-3B79-A7FD-67BD19471420> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7872000 - 0x795efe7 libvMisc.dylib (516) <C784D56E-112E-359F-848B-3419E0572EB4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x796a000 - 0x7d52ff7 libLAPACK.dylib (1128) <4E3D1289-2C98-3E53-BB8D-AD911357FF66> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7daa000 - 0x7f1bffb libBLAS.dylib (1128) <ACEF468C-5DB1-38F3-BCB2-6F3D7F2B2040> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7f42000 - 0x7f59ff3 libLinearAlgebra.dylib (1128) <B20FAAAA-1C76-3B20-B100-5FC90F7FE023> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7f61000 - 0x8059fff libFontParser.dylib (134.10) <1C490D97-6E83-3FC4-95FD-7E06DD8FBF68> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x80b5000 - 0x80feffb libFontRegistry.dylib (134.1) <6CF6177B-D5D6-3E7B-88BC-BE833D55018C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x811f000 - 0x8122fff libextension.dylib (55.2) <BE3B5B43-A1BB-3BB6-9CD9-946BC61241FC> /usr/lib/libextension.dylib
0x8128000 - 0x8156fff libarchive.2.dylib (30.50.1) <979CDD84-0D4A-373F-A725-70539F1135DE> /usr/lib/libarchive.2.dylib
0x8161000 - 0x8162fff liblangid.dylib (117) <34A0F807-755F-300B-B01F-AABAE3838451> /usr/lib/liblangid.dylib
0x8166000 - 0x8183fff libCRFSuite.dylib (34) <781A92EF-410E-39B2-953D-FEE12748D834> /usr/lib/libCRFSuite.dylib
0x818d000 - 0x81a7ff7 liblzma.5.dylib (7) <D0BC984D-5B33-328C-8F1E-7E9C41813433> /usr/lib/liblzma.5.dylib
0x81af000 - 0x81f6ff3 com.apple.AppleJPEG (1.0 - 1) <677BE130-F5AB-36F4-A51A-1FF20FC0085A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x8201000 - 0x8224fff libJPEG.dylib (1241) <E339475F-DEED-3794-B16C-315793D52D3B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x822c000 - 0x8287ffb libTIFF.dylib (1241) <CB5687CB-803D-33DA-A849-2DCDBDC48262> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x8295000 - 0x82bbffb libPng.dylib (1241) <4DD3850F-034B-3878-8401-7D40546D36AD> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x82c5000 - 0x82c9ffb libGIF.dylib (1241) <F620D80C-59D6-31CA-8678-7505F287274A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x82ce000 - 0x83d2ff7 libJP2.dylib (1241) <B7E5C1AF-81C8-3850-8245-EF1ED03B28DE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x83f7000 - 0x83f9ffb libRadiance.dylib (1241) <142D9DC6-A06D-36F0-8086-E4179491760C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x83fd000 - 0x844efff libcups.2.dylib (408.2) <425E4328-ECA1-31EE-B2C4-0D67FB8848BE> /usr/lib/libcups.2.dylib
0x8460000 - 0x8479fff com.apple.Kerberos (3.0 - 1) <92735F11-CF1C-3FA6-8682-9A30AC9E2651> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x8491000 - 0x84c3ffb com.apple.GSS (4.0 - 2.0) <2B5A899E-055E-3BEC-A8A1-F8570983389B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x84df000 - 0x84feffb libresolv.9.dylib (57) <C2C3810A-A45E-3375-B41D-6E1BECE1BA3C> /usr/lib/libresolv.9.dylib
0x8509000 - 0x857dfff com.apple.Heimdal (4.0 - 2.0) <DA206336-378C-3F65-9606-466BC3FDD824> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x85a4000 - 0x85a8fff libheimdal-asn1.dylib (398.40.1) <AB5482FE-56BF-3E43-8B33-1DEED3A3773D> /usr/lib/libheimdal-asn1.dylib
0x85ae000 - 0x85bbff7 com.apple.OpenDirectory (10.10 - 187) <6323752A-8CBE-3EF0-9934-F587EC24EF16> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x85cb000 - 0x85d4ffb com.apple.CommonAuth (4.0 - 2.0) <CEB9667F-4511-36E5-82EC-95CC1C48AC3B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x85db000 - 0x85f6ff7 com.apple.CFOpenDirectory (10.10 - 187) <E2363E55-6C66-3F21-9A05-421D63DF9FF2> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x8611000 - 0x8687fff com.apple.securityfoundation (6.0 - 55126) <3E59AEFA-3DEA-322A-A7BB-7B7B93E0286F> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x86b8000 - 0x8713fff com.apple.LanguageModeling (1.0 - 1) <9B39E059-F48E-31AF-B1B3-B0872F362627> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x8723000 - 0x8736fff libcmph.dylib (1) <2449B048-208E-36FB-9DFA-47E0F3BCF132> /usr/lib/libcmph.dylib
0x8743000 - 0x89dafff com.apple.CoreData (111 - 526.3) <93295B9D-6C48-3919-8B9C-A4291D3522CE> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x8aae000 - 0x8ab1fff com.apple.xpc.ServiceManagement (1.0 - 1) <78BFBBC9-FBEA-3522-A8B1-5BA7D7A442D3> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x8ab8000 - 0x8ae3fff libxslt.1.dylib (13.9) <6566B1B9-F099-338E-82B8-8696656D555C> /usr/lib/libxslt.1.dylib
0x8aef000 - 0x8c1dff7 com.apple.coreui (2.1 - 308.6) <5C418632-E00D-3864-B645-F2D993DE6455> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x8cdf000 - 0x8df5ff3 com.apple.desktopservices (1.9.3 - 1.9.3) <544FDA55-063A-3787-A55A-A54290E4BE6E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x8e70000 - 0x8e8fff7 com.apple.GenerationalStorage (2.0 - 209.11) <34CF76B2-8052-359D-816D-092608FB6919> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x8ea1000 - 0x9193ff3 com.apple.CoreImage (10.3.4) <6A0E17E6-9F56-3450-8892-670A9C489C30> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x9290000 - 0x92d3fff libGLU.dylib (11.1.6) <3682B11C-7897-3A56-A82F-3EB59CD41D93> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92e1000 - 0x92eafff libGFXShared.dylib (11.1.6) <784C99B9-4E89-3804-801A-364700D00133> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x92f1000 - 0x9301fff libGL.dylib (11.1.6) <9F457F9B-C393-3105-953A-1E0DA618DB76> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x9314000 - 0x9354ffb libGLImage.dylib (11.1.6) <7A079480-648E-3313-89B4-17CB578CAD33> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x935c000 - 0x935efff libCVMSPluginSupport.dylib (11.1.6) <27E51D50-D030-3BA8-AF6E-4317A2003944> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x9363000 - 0x9367fff libCoreVMClient.dylib (79.1) <3DB52AB1-D41E-3AC9-A355-1B6DCEDB4DFD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x936d000 - 0x9379fff com.apple.CrashReporterSupport (10.10 - 631) <9A6DF8E2-AE0F-3919-889A-CD7F79ABD6EC> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x9387000 - 0x93d8fff com.apple.opencl (2.4.2 - 2.4.2) <B9796163-3EC0-3FAD-B4E1-F83EA2A2DD94> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x93ea000 - 0x981dff3 com.apple.vision.FaceCore (3.1.6 - 3.1.6) <EF92C25B-3E33-379F-A862-75C2FCA8B386> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x9a32000 - 0x9a4fffb com.apple.Ubiquity (1.3 - 313) <9ED23769-0725-3D4B-B7F4-AF08020D73C3> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x9a60000 - 0x9a73fff com.apple.Sharing (328.17 - 328.17) <71EC4FF5-C6F0-3521-BADE-E8BD71AA7741> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x9a86000 - 0x9aacff7 com.apple.IconServices (47.1 - 47.1) <9C537499-B375-3F84-BF4A-EEF757FC26A9> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x9ac8000 - 0x9af4fff com.apple.ChunkingLibrary (2.1 - 163.6) <D5446A27-C51B-36D7-A4A1-3222A87F6F48> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x9b00000 - 0x9b24ffb com.apple.framework.Apple80211 (10.3 - 1030.71.6) <A133A567-C369-309C-B8BE-F43C9B1B3B61> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x9b2f000 - 0x9ba2ffb com.apple.framework.CoreWLAN (5.0 - 500.35.2) <812E25B3-2041-360E-8C1D-0CCA1E66D1EE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x9bd9000 - 0x9c88ff7 com.apple.Bluetooth (4.3.6 - 4.3.6f3) <11B6D154-AF78-3947-BAF1-35CD4CAC9C2A> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x9cde000 - 0x9d49ff7 com.apple.framework.CoreWiFi (3.0 - 300.4) <632A811D-4706-3ED7-85E3-DD2CDB47CF8F> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x9d87000 - 0x9d9afff com.apple.CoreBluetooth (1.0 - 1) <153F2DDE-CCCF-3C63-AF70-2EA306DACDCD> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x9daa000 - 0x9db8ff7 com.apple.SpeechRecognitionCore (2.1.2 - 2.1.2) <CDD0CAA1-DF2E-3FE1-AEE4-4C0823E6FD5C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x9dc5000 - 0x9e01ff3 com.apple.RemoteViewServices (2.0 - 99) <2839C2F1-88DA-3843-87BF-441A374A8967> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x9e29000 - 0x9f5bfff com.apple.UIFoundation (1.0 - 1) <B5B0D178-E1F5-3625-9391-46495E35D540> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x9fbb000 - 0xa048ff3 com.apple.PerformanceAnalysis (1.0 - 1) <C9CCC643-86AB-3538-B78E-3C9464C87072> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0xa099000 - 0xa164fff com.apple.backup.framework (1.6.5 - 1.6.5) <F2F66289-39DD-3033-A56B-DC8A9495C782> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0xa1e4000 - 0xa21eff7 com.apple.DebugSymbols (115 - 115) <D01FFA10-1734-31C5-B5A1-9CB61463FC15> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0xa23a000 - 0xa2ccff7 com.apple.CoreSymbolication (3.1 - 57020.2) <5F3895EF-7C0E-3246-A1C0-0A582548AB92> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0xa2df000 - 0xa31ffff com.apple.Symbolication (1.4 - 56045) <BE1C4846-DA11-365D-9B46-3FF130401839> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0xa33d000 - 0xa354ffb libexpat.1.dylib (12) <751B1CA1-D871-37AA-BE43-4131FF8B7747> /usr/lib/libexpat.1.dylib
0x64b00000 - 0x64b05fff com.apple.print.framework.Print (10.0 - 265) <7C3984BB-8337-3B90-A414-17C181A45744> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x8fe14000 - 0x8fe47dd3 dyld (353.2.3) <5E2682A5-D51C-3732-8DA0-7A2B2C0225BE> /usr/lib/dyld
0xfa100000 - 0xfa15dff7 com.apple.print.framework.PrintCore (10.3 - 451.1) <86895179-C54B-3D8A-B515-92DFA6315FC9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 50891
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=146.7M resident=51.9M(35%) swapped_out_or_unallocated=94.8M(65%)
Writable regions: Total=39.7M written=2536K(6%) resident=13.7M(34%) swapped_out=0K(0%) unallocated=26.1M(66%)
REGION TYPE VIRTUAL
Kernel Alloc Once 4K
MALLOC 19.1M
MALLOC (admin) 16K
Stack 64.0M
VM_ALLOCATE 8K
__DATA 14.4M
__IMAGE 528K
__LINKEDIT 30.7M
__OBJC 2216K
__TEXT 116.1M
__UNICODE 552K
shared memory 4K
TOTAL 247.5M
Model: MacBookPro8,1, BootROM MBP81.0047.B2C, 2 processors, Intel Core i5, 2.3 GHz, 8 GB, SMC 1.68f99
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x0198, 0x393930353432382D3032302E4130304C4620
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x0198, 0x393930353432382D3032302E4130304C4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.3.6f3 16238, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: ST500LM021-1KJ152, 500.11 GB
Serial ATA Device: OPTIARC DVD RW AD-5970H
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: BRCM2070 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Hub
USB Device: IR Receiver
Thunderbolt Bus: MacBook Pro, Apple Inc., 22.1
User ID: 501
Report Version: 11
cr2: 0xbf7ffffc
Logical CPU: 0
Trap Number: 14
Binary Images:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 50891
thread_create: 0
thread_set_state: 0
VM Region Summary:
REGION TYPE VIRTUAL
MALLOC 19.1M
MALLOC (admin) 16K
Stack 64.0M
VM_ALLOCATE 8K
__DATA 14.4M
__IMAGE 528K
__LINKEDIT 30.7M
__OBJC 2216K
__TEXT 116.1M
__UNICODE 552K
shared memory 4K
TOTAL 247.5M
USB Device: Hub
USB Device: Hub
geposted Fri 11 Mar 16 @ 4:58 am
Why not use VDJ 8?
geposted Fri 11 Mar 16 @ 6:49 pm
If your using El capitan try the free VDj-8 that may run smoother with your MAC New SW. but if not and you would like to use VDj-7 step your mac down to windows 7 or 98 using booth camp.and VDj-7 will ran OK.
geposted Thu 24 Mar 16 @ 6:43 pm
