I know there have been posts on this in the past, and many suggestions on scripts to change the default filter. But does anyone have a verified script for changing the default filter to the SBDJ plug in?
thanks in advance
thanks in advance
geposted Sun 13 Mar 16 @ 4:29 am
Just wondering - if you're using v8, what is wrong with the default filter?
geposted Sun 13 Mar 16 @ 11:51 am
Yes, using vdj 8.1. I don't love the the way the resonance sounds when setting to strong. The filter is the only feature on vdj that I think serato has the upper hand on.
geposted Sun 13 Mar 16 @ 1:19 pm
Have you tried adjusting the filter it has settings see -> filterDefaultResonance in audio options make sure u have ticked advanced
geposted Sun 13 Mar 16 @ 1:46 pm
Yes, setting is on strong. Thx
geposted Mon 14 Mar 16 @ 1:00 pm
there is also the costum setting
I have put the value
filterDefaultResonance 0.8
geposted Mon 14 Mar 16 @ 1:39 pm
In terms of number what is the setting for default and filter Resonance?
How do you set the filter to 0.8?
geposted Mon 14 Mar 16 @ 2:29 pm
from another post I
SBDJ wrote :
It takes a numerical value.
Subtle = 0.2
Default = 0.5
Strong = 0.95
Subtle = 0.2
Default = 0.5
Strong = 0.95
geposted Mon 14 Mar 16 @ 3:03 pm
I agree 0.8 would be ideal too. My setting option for filter is Default, Strong and Subtle, how do you get the decimal /numerical value option? I am using v2857.1116
geposted Mon 14 Mar 16 @ 6:47 pm
Just type over the words in the box
geposted Mon 14 Mar 16 @ 7:17 pm
thank you
geposted Tue 15 Mar 16 @ 1:28 am
