Topic: List View instead of Grid View VDJ8 - Page: 1
Okay I have no idea what I did but in my play list VDJ8 my songs are coming showing in a expanded "grid view" not a list where I can see more of the songs, I think this changed after a update. How can I change my playlist back to a list view. Thanks
geposted Wed 23 Mar 16 @ 2:35 am
Click on the small radio button (above the font resizing buttons) in the lower left corner of the interface and select Display List as List View. Grid view is likely checked.
Alternatively you can go to Options and set gridView to "no".
Thanks So Much!
the display list as gone
it wont showed up in my virtual
How can i change the grid list?
Which version are you using?
It wont be available if you are using the "Tablet" skin, which forces List to Grid.
i have the same problem....im in 4 deck mode but no list view option.....im using virtualdj8
scroll up.
that away ^^^
E'vitaerc The DJ wrote :
Okay I have no idea what I did but in my playlist, VDJ8 my songs are coming showing in an expanded "grid view" not a list where I can see more of the songs, I think this changed after an update. How can I change my playlist back to a list view. Thanks
I have the same issue, I VDJ8 and I cant switch to "list view". I have my layout set at "4 decks" and when I go to the radio button (on the side, below the mic icon) and click right, I get no option to change the view????
Been a long standing bug that's never been fixed
Goto options and set gridView to No
Another reason for no list view option can be if you have enabled touch screen mode in the settings
I went into settings and clicked "grid view" to "no" so that I can get a list view. However, my view stays as a grid. Frustrating!!!!!
On the default skin, at the top. Is layout set to tablet?
No, it is not set to tablet. It is currently set to "4 decks" in the default view. I did click on tablet and noticed that my playlists were still showing as grid. I clicked back into "4 deck" default view. And I've double checked my settings and "grid view" is still NOT checked. I just want my list view back!! Ugh!!
Checked no on touchscreen box in settings and now I have the list view. Sucks I can not use my touchscreen.
You can use your ts, you just have to use a different skin.
I can use my touchscreen with it off, it is just not as easy.
Do other ts skins force gridview?
Please who can help. my faded appears on the left side sometimes even when i have changed it to the right and vice versa. Please i need help.
Maybe if you explained what your faded is, and what how it's related to grid/list view of the browser....
80%
