hello, I normally use a pioneer sb to mix at home but its in for repair,
I dug out my Gemini first mix pro an hour ago
all the features work but when I want to listen to deck b while deck a is running with the fader down the track is being played as if I had the fader up
I will look around on here for help but someone must of had this problem and guide me onto a thread for help
kind regards
Tom W
kind regards
Tom W
geposted Tue 12 Apr 16 @ 5:57 pm
See if the FirstMix provides any ASIO drivers (check Gemini website, i think it does) and use those in the Audio setup. If not (or still need to use the WASAPI ones) , then check if the built-in sound card of the controller is set to 4 speakers (quadrophonic mode)
https://virtualdj.com/wiki/Pre-listening%20with%20headphones%20with%20Sound%20cards%20without%20ASIO%20drivers.html
geposted Tue 12 Apr 16 @ 6:03 pm
it was a setting to use onboard soundcard for headphones
got it working now
thanks alot
got it working now
thanks alot
geposted Tue 12 Apr 16 @ 7:54 pm
