Hello Virtual DJ!!
I have a VMS4.1 and I been using it for over 3yrs working without a problem till now. Virtual DJ works with the MIDI Controller (I can manage the songs, scratch them and set the cue points all the good things the VMS4.1 does). The problem I have is that its only coming out of channel 2.
Similar to what this user has
https://virtualdj.com/forums/140179/PC_Version_Technical_Support/VMS4_Problems___HELP__Both_decks_playing_off_one_channel.html
I have set up everything properly (I've been using this software for over 3yrs so I know how to set it up I would say) by seeing this https://virtualdj.com/homepage/djdad/blogs/4316/VMS4_Setup_Guide.html
Any help?
Funny Note... This happen to my first VMS4 and I had to upgrade to the VMS4.1 since i got frustrated. Maybe they break this way??
Thank you all in advance for your time and any help...
Any help?
geposted Wed 20 Apr 16 @ 5:56 am
Ferociouswilly wrote :
Hello Virtual DJ!!
Any help?
Any help?
After playing with it a little more... I've realized that if I change the midi channel switcher to CH1 USB and CH2 USB and assign the CF A to CH1 and CF B to CH 2 I can use everything normal and my fader works and everything else works with no problems....But what I want is CH2 USB with CF A and CH3 to CF B but it seems that nothing in CH3,CH4 works.... :-(
geposted Wed 20 Apr 16 @ 6:19 am
