Hi, I'm trying to map my Herculed Air+ controller in order to perform the Pitch Reset when I press SHIFT+SYNC
I assume I have to add this command to the SHIFT line, which has this default string:
toggle 'shift' & toggle '$shift'
I tried to add this:
& deck active var '$shift' pitch_reset : sync
at the end of the line, but it has not worked for me... I also tried to map another button to perform the "deck active pitch_reset" and it works, but I want to do this with the SHIFT+SYNC combo... Any suggestion? Thanks!
geposted Fri 22 Apr 16 @ 10:19 pm
Solved, just had to map the SYNC button lol
geposted Sat 23 Apr 16 @ 1:41 pm
