I am having trouble with the custom button feature. Is there a way to have a custom button start (play) deck 1 and crossfade from deck 2 at the same time. And then another custom button that would start (play) deck 2 and crossfade from deck 1 at the same time. Thanks for any help you can offer. I am looking at finally switching from another program to VirtualDJ but am trying to figure out a couple shortcuts I had on the other program.
geposted Wed 27 Apr 16 @ 2:48 pm
deck 1 play & crossfade 0%
deck 2 play & crossfade 100%
geposted Wed 27 Apr 16 @ 4:03 pm
I think that crossfade may be too instant, there is auto cross fade command but I'm not to familiar with it
try
etc
try
deck 1 play & auto_crossfade 5000ms
etc
geposted Wed 27 Apr 16 @ 5:30 pm
locodog wrote :
too instant,
No, it will crossfade smootly according to the default crossfade time. I don't remember but I believe it is 4s.
Plus, in your example you do NOT specify a direction to crossfade to, so it may imply unwanted behavior.
At least for it should've been like :
deck 1 play & auto_crossfade 5000ms 0%
deck 2 play & auto_crossfade 5000ms 100%
Sorry in my previous post I wrote 'crossfade' instead of 'auto_crossfade'.
geposted Wed 27 Apr 16 @ 8:12 pm
Thank you! That worked perfect.
geposted Fri 29 Apr 16 @ 9:32 pm
