Can someone develop a transformer scratch plugin? I dont have the quick coordination to use my numark controllor to get the effect to sound right. I have the crossfader set correctly. I'm thinking of the plugin or a script setting can be configured so that the crossfader slides 1% left or right. then back to 0% and it would create the effect.
    geposted Sat 14 May 16 @ 5:18 pm
          what about using a gate plugin .. there are some in plugins :-)
    geposted Sat 14 May 16 @ 6:10 pm
          Gate plugin? not sure which are those can you tell me the names?
    geposted Sat 21 May 16 @ 8:18 pm
          Audio Cut8  is the only vdj 8 one i see try that out :-)
    geposted Sat 21 May 16 @ 8:34 pm
          Thanks, i've played with that one a lot fine tuning it to 1/4 to 1/2 works. Thats the best im get til i master it, myself
    geposted Sat 21 May 16 @ 9:14 pm
          I use a Korg Nanopad2 ($50 US) and have mapped a button to trigger the Audio Cut, flanger, and a little reverb to create a sort of transformer effect. Haven't tried it with scratching... mainly because I suck at it. Lol. It'd be cool to hear what it sounds like though.
    geposted Sun 29 May 16 @ 2:59 pm
