Right who can shed some light on this. As I'm getting older the old mince pies EYES are getting worse, this has ended up with me struggling to see the songs in the browsers/ folders. Can the font size be changed is my question ?? And yes I do wear glasses, but having to wear two sets, Bi focals for normal, and Mid distance for seeing the laptop :-(
geposted Tue 31 May 16 @ 4:20 pm
In VDJ 7? Yes, there are some VDJ 7 skins which have adjustable font size. Check the download page.
In VDJ 8 it's a standard feature, built in to the browser.
geposted Tue 31 May 16 @ 4:26 pm
If you are using v7 let me know your skin and I'll check the xml for you if you like and as groovin says in v8 just use the automatic font adjust buttons > A- and A+ (usually coloured red and green) for best resolution of font for your eyes.
Oh, make sure you are wearing your jam jars or you'll miss them, they are tiny icons on standard skin... lol
geposted Tue 31 May 16 @ 5:12 pm
