So Im using my Pioneer DDJ-Ergos on VDJ ERGO Limited Edition and for some odd reason the sync wont work on the left deck. The right deck button works fine but on the left I have push the button on the controller and mainly it just doesn't do anything. I have never experienced this problem before and have no idea what could be causing it. All I know is it is not a problem with my controller.
Any thoughts?
Any thoughts?
geposted Fri 03 Jun 16 @ 10:38 am
Switch other deck to master shift - sync
geposted Fri 03 Jun 16 @ 11:51 am
A liitle explanation...
One deck is always the master, and the other deck(s) will sync to that.
If the left deck is the master, the sync button will work on the right deck, but if you try to press sync on the left (master) deck it won't do anything because sync always needs one of the other decks to be the master.
geposted Fri 03 Jun 16 @ 4:26 pm
