MAC OS X El Capitan 10.11.5.
I can only answer this checkbox with no, if I select yes this hint shows up again:
geposted Mon 06 Jun 16 @ 1:41 pm
If you have difficulty with the auto-update then you can always manually download from here:
https://virtualdj.com/download/build.html
geposted Mon 06 Jun 16 @ 1:44 pm
Thank you. I'll try this ;o)
geposted Mon 06 Jun 16 @ 2:04 pm
OK. Did work. Thanks again ;o)
geposted Mon 06 Jun 16 @ 2:08 pm
To clear things up (took from here: https://virtualdj.com/forums/210031/General_Discussion/_NEW__VirtualDJ_8_2.html?page=1), posted by sclavel:
Note2:
because of some permission changes in MacOS 10.11, you cannot auto-update from 8.1 to 8.2.
So if you are on Mac and want to install 8.2, download and install it from here:
(auto-update will work between 8.2 builds though)
Didn't read it, sorry ;o)
Note2:
geposted Mon 06 Jun 16 @ 9:44 pm
It worked on 10.11.6, I didn't have to use the link.
geposted Tue 07 Jun 16 @ 3:03 pm
