I noticed the Ask The DJ Root Element and so I clicked on it. It showed the message your guests can message you at and from that point on, everything was frozen; the mouse, couldn't even alt+tab to get away from 8.2 and finally had to hard power off the laptop. Also, it will not allow it to be unchecked in the Root Elements selection area. I went into options and highlighted it and hit delete which then showed it as unchecked in Root Elements yet it still appeared in the list.
geposted Mon 06 Jun 16 @ 9:45 pm
It works fine here.
Are you sure you don't have this entry ?
geposted Mon 06 Jun 16 @ 9:48 pm
I have that entry and know how to get to it. The problem is that I click on it and nothing happens, meaning it will not check nor uncheck that particular selection. If I click any of the others, they work just fine either appearing or disappearing from the root elements. When I simply click on Ask the DJ, it locks everything up to the point of having to hard power off the machine. It's almost like it is having trouble when trying to connect online to the service, and no it's not my internet, it is connect and running very well. I have used VDJ a very long time and usually figure out little things like this pretty quickly but I'm stumped on this one.
geposted Tue 07 Jun 16 @ 7:29 pm
How can i uncheck that Ask The Dj from root elements? Don't need it now.
geposted Wed 08 Jun 16 @ 5:51 pm
Use the menu. See the post above from PhantomDeejay.
geposted Wed 08 Jun 16 @ 5:58 pm
Don't work. See the post above from elite1.
geposted Wed 08 Jun 16 @ 6:06 pm
Now it works.
geposted Thu 09 Jun 16 @ 9:20 am
how did you solve it ?
geposted Thu 09 Jun 16 @ 9:24 am
After updating have to shut down VDJ and open VDJ again. Then i can uncheck Ask the Dj from root elements.
geposted Thu 09 Jun 16 @ 10:35 am
Yes, noticed that when first released. You have to restart VDJ.
Happened previously on 8.1 with other root elements as well.
geposted Thu 09 Jun 16 @ 10:36 am
Noticed the same thing too with having to restart for changes to take place. That's certainly not acceptable when performing live!
geposted Fri 10 Jun 16 @ 8:36 pm
Please check again with the latest Early Access build 3268.
Ask.the.Dj has been improved. Freeze should not occur now.
You now have 3 Right-click options for monitoring : off , always and when folder is focused.
geposted Mon 20 Jun 16 @ 3:02 pm
Now it doesn't even work
geposted Mon 20 Jun 16 @ 5:00 pm
Could you maybe be a little bit more specific?
geposted Mon 20 Jun 16 @ 6:18 pm
http://www.virtualdj.com/forums/210453/VirtualDJ_8_2_Technical_Support/Ask_The_DJ_in_v3268__feature_or_bug_.html
geposted Mon 20 Jun 16 @ 6:32 pm
