hi noticed that automix when set to to 0 sec in withe fade skip silence it does not work when set at 0 secs it stops playing and will not mix to next track this was a problem in 8.1 but was fixed
geposted Mon 06 Jun 16 @ 9:51 pm
Automix type : Fade (skip silence)
Automix Length : 0
Tracks are loaded and mixed as expected here
Automix Length : 0
geposted Mon 06 Jun 16 @ 10:04 pm
hi djdad mine is no working for some reason set like that which was my pref worked in 8.1
geposted Mon 06 Jun 16 @ 10:32 pm
just discovered this setting is not working in dual deck mode in the automix only in single deck mode
geposted Mon 06 Jun 16 @ 10:42 pm
Ok, issue has been reported.
geposted Tue 07 Jun 16 @ 2:13 am
thanks djdad
geposted Tue 07 Jun 16 @ 12:37 pm
Its been fixed for next update
geposted Tue 07 Jun 16 @ 3:09 pm
awesome thanks again dad
geposted Tue 07 Jun 16 @ 5:43 pm
