I'm using a numark mixdeck quad....so I have four channels on the mixer. I use two decks on VDJ. its using the middle sliders on my mixer. Its assigned as 1,2,3,4. ive tried to change the configuration in the vdj deck mapping but I cnat seem to get the sliders I want to use with the ones they have availbel. How do I assign specific sliders to specific decks?
    geposted Fri 10 Jun 16 @ 4:58 pm
          I believe the factory default mapping should offer mixer order 3124, but i may be wrong.
anyways, you will need to open the 4 Decks skin and right above the Crossfader on the skin, there is a small dot-button offering a menu.
you should be able to find 3 different options for mixer order and the controller should follow as well.
geposted Sat 11 Jun 16 @ 6:27 am
