Has anyone used it with VDJ? And issues or works fine as a vst plug in?
geposted Wed 22 Jun 16 @ 11:24 am
I've had mine for awhile, but only use as a hardware controller. What are the benefits to using as a VST?
geposted Wed 22 Jun 16 @ 7:10 pm
Once installing the vst plug in the rmx will act as a controller. Supposedly it should function the same way as if it was hardwired.
We shall see...
We shall see...
geposted Wed 22 Jun 16 @ 9:43 pm
If using a controller and if the plugin works, you get send/return feature of a mixer where you can choose which decks you want the FX to be applied to.
Failed several times in Mac. But I was able to make it work in Windows on my buddy's laptop.
Here's the thread I started prior to this one:
http://fr.virtualdj.com/forums/191878/General_Discussion/Is_there_a_way_to_use_Pioneer_RMX1000_as_plug-in_with_VDJ8_.html?page=1
geposted Wed 22 Jun 16 @ 10:26 pm
Thanks for that. So fsr no issues with the plug in on my desktop (pc). Will load it to my laptop (mac) once if gotten more used to it.
geposted Thu 23 Jun 16 @ 12:14 pm
I was watching a video on YouTube when I saw the Dj who was doing live mixing on vdj 8 RMX 1000. Does it get installed on free version of Virtual DJ??
geposted Tue 13 Feb 18 @ 12:42 pm
