How do I add this to the Auto Start folder??
geposted Wed 29 Jun 16 @ 4:32 am
Auto Start Folder? You mean like the programs that startup with Windows? If so, what version of Windows are you running?
geposted Wed 29 Jun 16 @ 5:08 am
You don't.
Just activate it when you need it, or if you really want it to activate on startup (which means video will always initialise) then add it to an ONINIT on a skin, keyboard or controller.
geposted Wed 29 Jun 16 @ 7:46 am
Bummer, maybe this can be changed in the future.......
geposted Wed 29 Jun 16 @ 12:10 pm
What's the difference with adding it to ONINIT of keyboard for example?
geposted Wed 29 Jun 16 @ 1:03 pm
Why lock them??
Either way I got my answer, Thanks.
geposted Wed 29 Jun 16 @ 3:18 pm
I used the keyboard for the controller mapping, but you could use your actual controller. Use the ONINIT key. I use mine to lower the master volume to 75% and to test, I added one of these below as well. Hope it helps.
ONINIT:
browser_gotofolder 'My Library'
or
browser_gotofolder 'History'
or
browser_gotofolder 'F:\mixes'
ONINIT:
or
or
geposted Thu 30 Jun 16 @ 5:54 am
Hi,
When I want to change the font, a dialog shows up that tells me I have no fonts installed.
On my pc there are a lot of fonts installed, so I don't get it.
What can I do?
What can I do?
geposted Fri 17 Feb 17 @ 3:30 pm
What is your Operating system ?
geposted Fri 17 Feb 17 @ 8:18 pm
My operating system is Windows Vista..
On my Vaio laptop (running Windows 10+) it is working fine...
thnx for reply
thnx for reply
geposted Sat 18 Feb 17 @ 6:32 am
