Forum: Addons
Topic: Remote Screen
geposted Tue 05 Jul 16 @ 6:45 am
Is there a Manual?
Edit: I viewed your youtube video. I had to extract the tablet skins first, and now they work.
Cheers...
DjSteveAU wrote :
Is there a Manual?
Cheers...
hello, what's the link to the youtube video
Any word on a Android version? Android tablets are lower cost than Ipads Thanks
The Remote is already available for Android systems.
This thread is about a remote skin. Skins are not system specific. They should work on either remote.
@kaleo, Thank you! Nice Work!
I have a problem:
If i Load "Remote Screen Deck LR 1024x768 Dev1.zip" on my IPad, i get a blank skin on my Ipad Device.
If load an other skin for example Remote Screen Deck LR 1024x768 Dev2.zip it looks good. I removed the app and installed it again, but no solution...
Any thoughts ?
See Screenshot...
THX
best it is possible to remote screens from 1 of the 2 tablets to run so that the micro usb cable on the other side. because now I have to take off the cable during transportation thanks in advance
Download button not working....Please help!
You need a license to download this plugin.
Hi! on last virtual dj version how we can use this remote skin? is not appear on remote skins list.
The skin contains several zip skins, so once you install from Extensions, you need to open the /Remoteskins folder and extract the Remote Scree.zip to the same folder (will add a few zip files) then you can select from VDJ Interface tab
