For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: MKV audio problems in 8.2
mizurPRO InfinityMember since 2003
All MKV files sound saturated even the visual waveform looks saturated.
I updated to 8.2 with latest klite codec pack installed.
Only mkv files have that problem.
Rolled back to 8.1 and the problem disappears, went back and forth several times always same result.
geposted Sat 09 Jul 16 @ 12:33 am
