Topic: AU plug ins
Are audio unit (AU) plug-ins supported in 8.2? I see the manual only talks about VST, please advise if I can still use plug-ins on a MAC.
thanks
geposted Fri 15 Jul 16 @ 3:26 pm
Refreshing this post, any input would be greatly appreciated! thx
geposted Mon 18 Jul 16 @ 7:30 pm
As far as I can see AU plugins are not supported, however VST is.
geposted Tue 19 Jul 16 @ 11:58 am
Thanks Scott.
Does anyone have experience running VST plug-ins on a mac? I know there are programs to do it, but none that I'm familiar with. Any recommendations would be appreciated!
Matt
geposted Tue 19 Jul 16 @ 2:29 pm
You can get proper Mac VST plugins. In fact from some reading it seems some AU plugins are just wrapped Mac VSTs.
Here's some examples:
http://www.kvraudio.com/plugins/macosx/vst-plugins/effects/newest
I haven't actually tested myself to see if they work OK - it looks like they should but it's entirely possible I've missed something so I will boot up the Mac later on and test some to be sure.
geposted Tue 19 Jul 16 @ 2:37 pm
That looks like a great site, however I am specifically looking to get through rmx-1000 plug-in working on my mac.
The vst works fine on my desktop pc, but no joy using the vst or au on my gig machine (macbook)
geposted Tue 19 Jul 16 @ 2:57 pm
Unsure if the Mac version of that plugin is a VST or an AU. I'll have a look later and see what I can find out.
geposted Tue 19 Jul 16 @ 5:59 pm
I verified I downloaded the MAC plugin for the rmx which does come with a VST version however it still does not function properly in VDJ. The actual plug in looks like the RMX on screen which the hardware controls, instead I am getting a large box with about 100 different knobs. I do get some sound from the plug-in but it definitely does not function as it should (and does on the PC).
I noticed in the effect section of the manual for VDJ 8 it states "*VST and VSTi Effect support is not currently available for Mac computers". Does this mean VDJ itself does not work with VST plug-ins on a Mac? So essentially I am SOL?
Is this on the to do list by any chance?
geposted Tue 19 Jul 16 @ 11:43 pm
VST GUIs aren't implemented on Macs yet, but it's on the todo list :)
Perhaps that's related to something from the GUI that isn't immediately obvious due to not being able to see it.
That's incorrect, but I will do some further testing and have a look at implementing the GUI support. I will also have a look at what is involved with AU as well but make no promises there ;)
geposted Wed 20 Jul 16 @ 6:05 pm
Thanks Scott. I would be happy to test if you need someone.
I appreciate you getting back to me, and of course the time and effort the VDJ team put in as always!
geposted Thu 21 Jul 16 @ 3:04 am
Scott, thank you for including this with the latest early release. I am now able to see vst plug in correctly on my mac. While playing around with it, I did have a few crashes. Specifically when I used the overdub feature on the RMX-1000. Are you able to view my crash report or can I sent it over to you? If the latter, please advise where I can find the crash report to send over.
Thanks again for addressing my issue!
Matt
geposted Tue 02 Aug 16 @ 12:20 am
I can see the crash, it occurred whilst the VST was processing audio.
I will have a look and see if I can see anything obviously wrong or any safety we can add, but I can't promise anything as it will be difficult to replicate as I can't install the VST without having the hardware :(
geposted Tue 02 Aug 16 @ 2:48 am
Thanks for that.
geposted Tue 02 Aug 16 @ 11:15 am
I know I'm late to the party but did this ever get fixed?
geposted Fri 04 Nov 16 @ 7:00 pm
