is there a way the song i loaded into a deck that i wanna put in automix list or into a crate ...can i drag from the deck into the location i want instead of having to search my library for the song all over again..
this weekends wedding the bride would ask for a song then request i play a different song and i found myself wishing i could just drag the song somewhere
thanks
thanks
geposted Mon 18 Jul 16 @ 6:05 pm
There's an option to dump unplayed tracks in your sidelist automatically if you replace or unload it without playing or before your time set in historyDelay
saveUnplayedToSidelist
geposted Mon 18 Jul 16 @ 6:22 pm
Yea think im gonna have to change sidelist view ..i was using automix and a wedding folder most of the night .untill the dancing started
geposted Mon 18 Jul 16 @ 6:34 pm
You can have both. If you enable showHorizontalSidelist then restart VDJ you can drag the sidelist up from the bottom of the browser to show as much or as little as you want whilst also keeping your automix panel at the side.
geposted Mon 18 Jul 16 @ 6:46 pm
Jus was reading that..thanks..no2 if someone asked for a song and i thought it was a hot track it wouldnt be in sidelist cause i played it tho right ..so instead of jus dragging to lets say new hot song folder..i would first have to search for it again in order to put it in a folder or is there another way
geposted Mon 18 Jul 16 @ 7:19 pm
No, you would have to search for it again .... hardly an issue though?
It's not possible to drag a song from a deck at present.
geposted Mon 18 Jul 16 @ 7:42 pm
On a custom button or pad
search '`get_loaded_song "title"`'
a step further, move it automatically
search '`get_loaded_song "title"`' & virtualfolder_add 'HotTracks'
geposted Mon 18 Jul 16 @ 7:57 pm
How about this? Instead of loading it to the deck first, add it to your sidelist first. You can drag it to the deck from there and it will stay in the sidelist if you have VDJ suitably configured.
geposted Mon 18 Jul 16 @ 8:01 pm
Heads up you don't need to restart V8, you just need to refresh the skin, IDKW atomix don't just have that happen automatically when the setting changes
geposted Mon 18 Jul 16 @ 8:07 pm
Thanks everyone for the ideas
geposted Tue 19 Jul 16 @ 10:57 am
search '`get_loaded_song "title"`' & virtualfolder_add 'Hot Tracks'
i liked this idea so i tried this and the first try it crashed vdj
and after that its works but clears the folder of any other tracks temporarily besides the one u just added
when u browse away and back the other tracks return
either the script has something wrong or there is a bug here.....
maybe if there is a way to return to where u were before the click? as it is it takes u to the virtual folder.
geposted Tue 19 Jul 16 @ 11:18 pm
try this
search '`get_loaded_song "title"`' & repeat_start 'rsWait' 500ms 1 & virtualfolder_add 'Hot Tracks' & goto_last_folder & clear_search
I forget script is faster than the browser
geposted Wed 20 Jul 16 @ 12:10 am
awesome thanks so much
geposted Wed 20 Jul 16 @ 12:32 am
I can see this one could be good for reviewing new tunes and sorting them to virtual folders, although it'd have to be a DIY pad page as eveyone has different vfolder names.
It might be worth a pad with 'your vfolder name here' if atomix would accept that.
geposted Wed 20 Jul 16 @ 1:09 am
OT:
I'm using this mapping to prelisten new tracks:
http://virtualdj.com/user/PachN/blogs/5377/Prelisten_mapping.html
geposted Wed 20 Jul 16 @ 8:57 am
