Topic: Pioneer DDJ-RR now supported?
Hi all, just got a DDJ-RR, which I can't see anywhere that says its supported but it seems to work fine?
geposted Fri 22 Jul 16 @ 3:47 pm
Hmmmmm. Thought I had. Very happy either way!
Click the 'info' button [top right]
The ' info ' does not appear to me when I select DDJ - RR but appears when I select DDJ -SR
Maybe that is the cause. I will resolve this situation soon. :)
Thank you a lot.
Did you get this sorted. I've just ordered one but have had the following reply from PioneerDJGlobal twitter feed. "I'm afraid Virtual DJ is not natively supported"
Pioneer do not support VDJ but VDJ supports the controller :)
Yeah, what they should've said was "Our product doesn't support Virtual DJ but Virtual DJ supports our product" :-)
and the winner is ......Pioneer
