Forum: VirtualDJ Skins
Topic: Skins on Mac
Hi,
I have a Mac and am creating a skin for VDJ. When I zip the files I get an error when trying to use the skin in VDJ 8. At first I thought I was making errors, but then I took the default skin, unzipped it and rezipped it (without changing it) and that gives the same error : " Impossible to open skin... " so it seems zipping on the Mac is not compatible with VDJ.
I also tried zipping via the terminal where one can specify to leave out any Mac OS related files... but that doesn't work either.
Has anyone gotten this to work on the Mac?
Thanks in advance,
Ramon
geposted Tue 26 Jul 16 @ 5:30 pm
Solved this by using a different zip program than the default compress function that comes with the mac.
geposted Sat 30 Jul 16 @ 12:12 pm
