I wish VDJ 8 had an automix like OtsAv so we would not have to keep changing the type and length to make it a nice transaction when we are entertaining the dance floor or going to the bathroom. I have tried using the automix edit but its doesn't usually sound perfect everytime
geposted Sun 31 Jul 16 @ 2:11 pm
you will probably have to describe how it is different or nobody will understand, i know i do not.
geposted Sun 31 Jul 16 @ 2:56 pm
OtsAV Auto DJ feature
The Auto DJ feature has extremely accurate automatic mixing point technology. You will hear intelligent, automated mixing that you would expect to hear from a live professional DJ or radio station.
OtsAV analyzes the way that a song starts and ends and works out an appropriate mix. It does not simply overlap the songs by a set number of seconds like some other programs do as they crudely attempt to mix. With OtsAV, you get perfect mixes every time.
geposted Sun 31 Jul 16 @ 8:12 pm
To Enable/Disable Auto DJ click the Enable/Disable Auto DJ Mode icon on the toolbar.
Click here to discover what Auto DJ feature means to a Pro DJ
The Auto DJ feature will enable you to concentrate on more important issues, such as reading and interacting with your crowd. You'll come to rely on this feature and most certainly appreciate the opportunity of being able to take a toilet break without having to play Stairway To Heaven first!
Note: You can always over-ride the automated mixing functionality if you wish to manually mix.
If you have setup your music to work with Automated beat mixing, you can perform a perfect beat mix without even being behind your mixing console!
Click here to discover what the Auto DJ feature means to a Radio or TV Station
The Auto DJ tool provides dependable seamless mixing. This tool will save you an incredible amount of man power and time as it eliminates the need to prepare your music in advance. You will be able to concentrate on preparing your schedules knowing that OtsAV is in control of your radio mix. You'll come to rely on this feature and most certainly appreciate the time saved.
If your station needs programmed beat mix shows, use the Automated beat mixing feature.
Click here to discover what Auto DJ feature means to an AV Enthusiast
If you're an AV enthusiast, imagine being able to have perfect radio mixing in your home or office. Music that flows is music that sooths, calms, and energizes all with no annoying attention-grabbing silences. And when you throw your next party, you'll have just what you need to sound like a pro.
Note: Auto DJ is also used when using the Automated beat mixing feature.
geposted Sun 31 Jul 16 @ 8:17 pm
Just set Autmix mode to "smart" and VDJ will Mix them IF they are properly mixable. Of course if will fail if the current track has 120 BPM and the next one 80 or something. But with tracks nearly the same BPM it works very well.
geposted Mon 01 Aug 16 @ 12:45 pm
