Discussion about Automix Live
geposted Sun 31 Jul 16 @ 7:29 pm
Automix Live brings most of the automix options accessed by the mouse to your pads
Access the search bar, switch browser focus, add and remove files, change the fade length, all mix now options, change the mix type, and more.
Less mouse work, more control.
geposted Mon 01 Aug 16 @ 12:15 pm
As promised licencing restriction dropped, now open for all users.
geposted Mon 03 Oct 16 @ 11:24 pm
I do not understand what DOWNLOAD Aas use? please abaut
geposted Sun 30 Oct 16 @ 2:49 am
I don't understand what you mean.
geposted Sun 30 Oct 16 @ 2:54 am
Hey Loco,
I would drop the File Add in favour of the new command ;-)
geposted Mon 24 Apr 17 @ 10:54 am
hola soy nuevo en esto y no se como empezar a usarlos e instalarlos si me podrían ayudar seria fantástico, alguna solución favor de hacérmelo saber por mi Mail
geposted Fri 16 Jun 17 @ 6:04 am
Hello Locodog, great scripts.
I only modify the "Playlist Add" button from
playlist_load
to
holding 800ms ? playlist_load : nothing
Just to avoid replace the automix list by error, so I need to press this button for at least 0.8seconds to replace the list.
Thank you for sharing this Addon.
playlist_load
to
geposted Tue 08 Aug 17 @ 10:43 pm
Hey i have numark mixtrack platinum... Here no button to access the addons.... How to use the mods.... I am a beginner.. so i have no idea about it.... Please help
geposted Sat 24 Feb 18 @ 3:51 pm
please how can i add the beat pad to my virtual dj 2020 i try to download it but it says i should download through virtual dj and i dont understand what that means
geposted Mon 02 Dec 19 @ 11:22 am
geposted Mon 02 Dec 19 @ 5:47 pm
