Can i use push 1 or push 2 as controller for vdj8?
Mapping exist already?
Best regards,
Cédric
Best regards,
Cédric
geposted Mon 01 Aug 16 @ 12:12 pm
If you go to Options - Devices and click open the dropdown on the top, than select "Show all devices" you will find a list of all supported controllers. If it is not there and not here, no.
geposted Mon 01 Aug 16 @ 3:26 pm
No, Ableton Push units are not supported at the moment.
geposted Tue 02 Aug 16 @ 7:47 am
Thank you very much.
geposted Thu 04 Aug 16 @ 9:28 am
Hey Cedric,
My advice would be to take a look at the Novation Launchpad Mk2, it's supported and does the job well.
best
ray
best
ray
geposted Thu 04 Aug 16 @ 9:45 am
