Topic: CPU Usage and subsequent temperature rise
GadgetzPRO InfinityMember since 2007
So I popped a mix on to start the night and loaded a second, first one finished and I started the second.
The CPU then went on a mission and as a result the temperature shot up, I popped a new track in the first deck, 2nd mix still playing and everything was back to rights.
I am able to replicate the behaviour and have a video that I'll upload asap.
I've had a quick flick through and can't immediately see if anyone else has posted it.
Apologies if they have and I've duplicated.
geposted Thu 04 Aug 16 @ 1:00 am
How long are those mixes? And what file format?
geposted Fri 05 Aug 16 @ 9:27 am
Mp3 50 mins and 20 mins, it's fine whilst loading and playing, it's when the first mix finishes and the second is playing.
Like vdj is still trying to do something with it even though it's stopped.
Im pretty sure it didn't do it before.
geposted Sat 06 Aug 16 @ 6:06 am
No I can't reproduce that.
geposted Sat 06 Aug 16 @ 7:52 am
what is the CPU usage meter at when this high temperature occurs?
and what are you computer specs
geposted Sat 06 Aug 16 @ 10:00 am
The cpu goes high when the first mix finishes.
Temp increases as a result of increased cpu.
It runs fine so long as I reload a new track or eject the finished track.
Macbook Pro 2.86ghz
Ssd
8gb Ram
512 graphics
The machine is only used for DJing and copes very well with vdj as a rule.
I'm convinced this is some minor bug, that some process continues when that first deck finshes.
I'm having trouble uploading the video though
geposted Sun 07 Aug 16 @ 4:54 am
Maybe a Mac thing?
As I said, I can't reproduce it, but I'm using Windows.
geposted Mon 08 Aug 16 @ 9:10 am
Are your mixers analyzed for BPM e.t.c. before you load them on decks ?
When you load on a deck a file that hasn't been analyzed before, VirtualDj will automatically analyze the file as you load it.
However, analyzing two big files simultaneously may increase CPU usage.
geposted Mon 08 Aug 16 @ 12:10 pm
No heat issues with my Mac.
geposted Mon 08 Aug 16 @ 12:24 pm
