Forum: VirtualDJ Plugins
Topic: loop_position & param_bigger '`get_var "stutterlength"`' ?
I've got an idea for a new pluggin but am wanting to get a rough feel if it's worth making by trying a script version, but I can't get this to work
repeat_start_instant 'muteloop' 33ms & loop_position & param_bigger '`get_var "stutterlength"`' ? level 0 : level 1
"stutterlength" is set by a custom dial, with just
set "stutterlength"
I've tried juggling loop pos, bigger and get var around but I haven't found the right order.
geposted Sat 06 Aug 16 @ 7:39 pm
Did you try with
param_buffer "`loop_position`" "`get_var 'stutterlength'`" ? a : b
Thanks for the reply.
param buffer is a new one on me [sounds like pluggin work, not script], I'll assume you mean param bigger.
I've just tried [I also tried buffer too]
repeat_start_instant 'muteloop' 33ms & param_bigger "`loop_position`" "`get_var 'stutterlength'`" ? level 1 : level 0
and it's not working here, I'm always getting the 'b' reply, I've checked for typos.
I'll take the plunge and start writing it as a pluggin
