Hello to my backup computer I want a plugin for version 7.
The skin virtual dj 7 (4Decks Swap) states: - Added Battery Status Indicator (Requires SBDJ Battery Status Plugin) but it is not found after search.
thank you in advance if a person in the solution.
geposted Tue 09 Aug 16 @ 11:39 am
http://www.virtualdj.com/addons/13066/SBDJ_Battery_Status.html
search all effects
search all effects
geposted Tue 09 Aug 16 @ 11:57 am
Google helps to find it....
geposted Tue 09 Aug 16 @ 11:58 am
thank you
geposted Tue 09 Aug 16 @ 12:06 pm
