I have two wishes for broadcasting they both relate to PC to PC broadcasting
1. Configurable port ... my ISP prohibits inbound traffic on ports 8000 - 8015
2. Implementation of UPnP for PC to PC on windows PCs (what this does is let the software temporarily open ports on your firewall and router if needed and when the use is over they close automatically)
more info UPnP
https://technet.microsoft.com/en-us/library/bb727027.aspx
https://msdn.microsoft.com/en-us/library/windows/desktop/aa382303(v=vs.85).aspx
thanks
the shoutcast and icecast broadcasting are perfect the way they are thanks for that :-)
more info UPnP
thanks
geposted Sat 20 Aug 16 @ 5:17 pm
1. Check the broadcastDirectPort option
2. We are working on it :)
geposted Sat 20 Aug 16 @ 5:31 pm
thanks i'll try the port change thanks
and yes i can now make it work woohoooo
geposted Sat 20 Aug 16 @ 6:39 pm
