Can anyone tell me how to use the ignore drives calculator?
geposted Mon 05 Sep 16 @ 1:03 am
You just check all the drive letters you don't want to be used by VDJ.
Take the calculated number and paste it to the VDJ's "ignoreDrives" setting.
geposted Mon 05 Sep 16 @ 1:21 pm
not working in build 3398 for me or maybe i don't understand how it works .. does it actually hide the drive or does it just not ever add anything from there to the database?
if it supposed to hide the drive from sight that isn't working.
geposted Mon 05 Sep 16 @ 2:40 pm
It just ignores any entries to the database.
geposted Mon 05 Sep 16 @ 2:42 pm
thank you so it must be working then :-)
geposted Mon 05 Sep 16 @ 2:43 pm
It only prevents a database on that drive to be read or written.
If you do decide to access the drive and it finds songs there, they will still be added to the database stored on the master drive (typically your documents folder on c drive)
geposted Mon 05 Sep 16 @ 2:52 pm
So when you download ignore drives calculator,what folder should it be stored in & then how do open it to use it?
geposted Mon 05 Sep 16 @ 9:48 pm
It doesn't matter where you store this app. It is a stand-alone application with no connection to VDJ.
It does only calculate some numbers like:
A=1, B=2, C=4, D=8 ...
If you decide to ignore drives B and D the programm will display you 10.
Just click on the setup.exe and it will install the programm to a location of your choice.
geposted Wed 07 Sep 16 @ 9:35 am
