I feel like it would be an excellent tool to be able to manually trigger a cut in milkdrop without needing to use the mouse, is there any way to do that?
geposted Sun 11 Sep 16 @ 11:05 pm
effect_button 'milkdrop8' 2
or
deck master effect_button 'milkdrop8' 2
or
geposted Mon 12 Sep 16 @ 7:04 am
Fantastic, thank you. Is there any instruction manual to find out more about these instructions?
geposted Mon 26 Sep 16 @ 11:15 am
https://virtualdj.com/wiki/VDJ8script.html
https://virtualdj.com/wiki/VDJscript_verbs_v8..html
and look for the long post on this thread for in depth information on repeat start scripts
https://virtualdj.com/forums/212660/VirtualDJ_8_2_Technical_Support/Proper_Echo_out.html
geposted Mon 26 Sep 16 @ 1:03 pm
Also here's a tutorial on using repeating scripts and load_pulse to automatically perform actions when a track is loaded.
https://virtualdj.com/user/locodog/blogs/5458/How_to__Perform_A_Action_Automatically_When_A_Track_Is_Loaded.html
geposted Mon 26 Sep 16 @ 2:35 pm
I actually meant "Is there any instruction manual to find out more about [the instructions for the milkdrop plugin]?
I can see that your script just calls the second button on the milkdrop settings panel, I assume calling the other buttons is similarly simple. Your other resources aren't helpful to me in this specific case but I'm sure they will be in the future. Thank you for your time :)
geposted Wed 12 Oct 16 @ 8:49 pm
change the number u get the other buttons :-)
geposted Wed 12 Oct 16 @ 9:37 pm
Every plug-in has buttons and sliders.
The logic to control them is always the same:
effect_button 'effect name' button nr
and
effect_slider 'effect name' slider nr
For sliders you can also set their value directly via vdj script:
effect_slider 'effect name' slider nr 38%
This is useful if you want to "save" a slider's position as a preset
Finally, for VST effects, all their buttons are treated as sliders (technical limitation of VST wrapper)
Therefore in order to control a button of a VST effect you need the following code:
effect_slider 'myVSTeffectname' 3 0% ? effect_slider 'myVSTeffectname' 3 100% : effect_slider 'myVSTeffectname' 3 0%
In this example, number 3 represents the third parameter of the effect.
On VST effects parameters get the order their author defines them on VST and all sliders and buttons have the same class. This means that on a VST effect parameter 1 may be a button, parameter 2 a slider e.t.c
geposted Thu 13 Oct 16 @ 11:57 pm
"effect_slider 'effect name' slider nr 38%"
what does 'nr" stands for or what does it make happen? thx
geposted Fri 14 Oct 16 @ 1:50 am
Number
geposted Fri 14 Oct 16 @ 4:34 am
thanks
geposted Fri 14 Oct 16 @ 10:24 am
effect_slider 'effect name' sliderNumber 38%
Example:
effect_slider 'flanger' 1 42%
or:
effect_slider 'echo' 2 60%
geposted Fri 14 Oct 16 @ 6:28 pm
