For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to remove, move or modify posts.
Topic: Pitch fader logarithmic? with Denon MC-4000
I realised that the pitch fader doesn't work properly with the Denon MC-4000
There's no direct correlation between the fader in the controller and the one in the screen.
Let's say the pitch range is 10%
From 0% to +-9% works at one precision, but from +-9% to +-10% the displayed value moves much slower.
geposted Thu 15 Sep 16 @ 2:28 pm
This is something determined by the hardware. A fader usually provides linear data from one end to the other, but that may not be the case for some units. To be honest i see no usefulness to get a different precision near the end. But anyways, this is something we cant change in the mapping files.
geposted Thu 15 Sep 16 @ 2:44 pm
Supposed that... but as in serato it seems to work fine, I was expecting more something like implement in future versions an option to choose the mapping function/parameters of the faders, like the crossfader and the jogs (linear, logarithmic...) ^^
geposted Fri 16 Sep 16 @ 12:58 pm
