I'm new to the podcasting. Is there a way to download my mix or listen to offline?
geposted Fri 16 Sep 16 @ 11:14 pm
If you mean after you are done, just use the record feature.
That creates an audio file, like an mp3, of your whole mix.
Then you can grab the file and put it anywhere you like, like you would do with any other audio file
Remember to turn your output up pretty high when recording
Also remember that you cannot use any CU content in a recorded mix
If you need for other people to have access to your mix I would do the same thing, and then upload it to a mix service like MixCloud
If you want people to listen to your mix while you are doing it, you can use the broadcast feature.
That is also pretty easy to set up, but you should check the manual for that
geposted Tue 20 Sep 16 @ 2:07 pm
How to download the software
geposted Mon 08 Jul 19 @ 4:43 am
http://www.virtualdj.com/download/index.html
geposted Mon 08 Jul 19 @ 8:34 am
Can it work on phone
geposted Tue 09 Feb 21 @ 11:18 am
VirtualDJ is currently a computer software for Windows and macOS.
But you can use your phone as a controller if you already have the software running on a computer.
See here: https://www.virtualdj.com/products/vdjremote.html
geposted Tue 09 Feb 21 @ 11:20 am
Will virtual dj mix with phone
geposted Mon 20 Sep 21 @ 7:29 am
read the post above yours.
geposted Mon 20 Sep 21 @ 10:06 am
