Hi,
Is there a way Virtual DJ can display cue point names instead of the numbers 1 to 8 here:
Thanks
Thanks
geposted Sun 18 Sep 16 @ 10:49 am
Option; cueDisplay
geposted Sun 18 Sep 16 @ 11:12 am
locodog wrote :
Option; cueDisplay
Thanks for your quick response.
I have changed the cueDisplay to name but its still not displaying the name. Do you know why?
geposted Sun 18 Sep 16 @ 11:24 am
In the example above, I have called the first cue 'Start Here'
But the Cue Button still reads 1.
geposted Sun 18 Sep 16 @ 11:25 am
That will be inside the skin then, you'll have to ask the developer to add support or ask for advice how you can reskin.
geposted Sun 18 Sep 16 @ 11:45 am
Thanks...
I have noted the default skin does show the names.
geposted Sun 18 Sep 16 @ 11:47 am
skin must be 8.2 compatible. Try it on the default skin ..it works.
geposted Sun 18 Sep 16 @ 1:46 pm
